Differentiability of multivariable functions
In summary: Yes, it is possible for a function to have both directional derivatives exist and be continuous, but still not be differentiable at that point.
Sho Kano
372
What does it mean for a ##f(x,y)## to be differentiable at ##(a,b)##? Do I have to somehow show ##f(x,y)-f(a,b)-\nabla f(a,b)\cdot \left( x-a,y-b \right) =0 ##? To show the function is not though, it's enough to show, using the limit definition, that the partial derivative approaching in one direction is not equal to the partial from another direction right?
Yes that is sufficient, but it is not necessary. A function may have both those partial derivatives exist and be equal, yet not be differentiable at that point.
So to summarize, because ##f(x,y)## is a surface, to show that the function is diff at a point, we have to take into account all the partial derivatives in all directions at the point, and they all have to exist. Another option is to only look at the partial with respect to x or y, and then approach in different directions; if they are different, then the function is already not diff. However, if they are the same, it still does not guarantee diff because we can approach in infinitely many ways? Then that means currently, I can only disprove whether or not a function is diff. Is this where the "gradient" definition comes in?
There is usually an easy way to prove differentiability, using the multidimensional differentiability theorem. All you need to do is show that both the ##x##-direction and ##y##-direction partial derivatives of ##f## exist and are continuous on an open set containing ##(a,b)##
andrewkirk said:
All you need to do is show that both the xxx-direction and yyy-direction partial derivatives of fff exist and are continuous on an open set containing (a,b)
What about all the other directions? I thought a tangent plane had to exist in order for ##f(x,y)## to be diff
The tangent plane will exist if the criteria for that theorem are met. Consider the function ##f:\mathbb R^2\to\mathbb R## whose value is 0 except when ##x=y\neq 0##, in which case the value is 1.
##\frac{\partial f}{\partial x}(0,0)## and ##\frac{\partial f}{\partial y}(0,0)## both exist but ##f## does not satisfy the requirement that it be partial differentiable in the ##x## and ##y## directions throughout some open set containing (0,0), because any such set will contain a point ##(x,x)## at which neither the ##x## nor ##y## direction partial derivative exists.
I don't understand, how do those partials exist? Here is a chart I saw in a video (arrow means "a" implies "b")
Continuous partials as in a ##{ C }^{ 1 }## function. ##{ C }^{ 1 }## meaning only with respect to x and y, or all directions?
This function isn't ##{ C }^{ 1 }##, but is differentiable right? Meaning it implies continuity and existence of partial derivatives
They exist because a partial derivative is defined as a limit, and it exists if the limit exists. Your understanding of this will be greatly aided if you try to work out the value of those two partial derivatives at (0,0) using the limit. If you don't remember the formula for the limit, you will find it in my primer on [URL="https://www.physicsforums.com/insights/partial-differentiation-without-tears/"]partial differentiation[/URL].
Yes. You can also look at what happens when you "approach" along a curved path.
In general, there is a difference (both in definition and in numerical value) between a "double limit" ##\lim_{(x,y) \rightarrow (ab)} g(x,y) ## and the two "iterated limits" ##\lim_{x \rightarrow a} ( \lim_{y\rightarrow b} g(x,y))## and ##\lim_{y \rightarrow b} ( \lim_{x\rightarrow a} g(x,y))##. And the two iterated limits are not necessarily equal.
The definition of "differentiable" for a function of two variables is stated using an application of the "double limit".
The epsilon-delta definition of a limit doesn't contain any definition of a separate concept of "approaches". The word "approaches" is merely a part of a statement that is defined "as a whole" by the epsilon-delta language. In particular, the definition of the double limit doesn't say anything about "approaches along a line" or "approaches along a curve".
Related to Differentiability of multivariable functions
1. What is the definition of differentiability for multivariable functions?
Differentiability for multivariable functions refers to the property of a function that allows us to calculate the rate of change or slope of the function at a specific point in the domain. In other words, a multivariable function is differentiable at a point if it has a tangent plane at that point.
2. How is the differentiability of multivariable functions different from single-variable functions?
In single-variable functions, differentiability is equivalent to the existence of a derivative at a point. However, in multivariable functions, differentiability is a more complex concept as it involves the existence of a tangent plane and partial derivatives in multiple directions.
3. Can a multivariable function be differentiable at one point but not at another?
Yes, it is possible for a multivariable function to be differentiable at one point but not at another. This is because differentiability depends on the behavior of the function at a specific point, and a function can have different behaviors at different points in its domain.
4. What are the necessary conditions for a multivariable function to be differentiable?
The necessary conditions for a multivariable function to be differentiable at a point include the existence of all partial derivatives at that point and the continuity of these partial derivatives. Additionally, the partial derivatives must be equal along all directions at the point.
5. How is differentiability related to continuity in multivariable functions?
In multivariable functions, differentiability implies continuity. This means that if a function is differentiable at a point, it must also be continuous at that point. However, the converse is not always true – a function can be continuous at a point but not differentiable at that point.
