Differentiable Automorphisms of ℂ
In summary, the conversation discussed the existence and properties of nontrivial differentiable automorphisms of the complex numbers. It was mentioned that there are many automorphisms, but only one article was found that discussed them. The article stated that AC is often necessary to construct them, but it was unclear if it was always the case. It was also mentioned that the identity and complex conjugation are the only continuous automorphisms, and any others would have to be discontinuous. It was suggested to read a specific article for a more detailed analysis.
alexfloo
192
Are there any nontrivial differentiable automorphism of the complex numbers? I know there are many automorphisms, but I could only find one article that discussed them. I didn't read the entire thing, but it mentioned that AC is often necessary to construct them, but I didn't see whether it said that was always the case.
Obviously, there's the identity; and then there's the conjugate which is trivial and continuous but of course not differentiable. My intuition is that any others would have to be pretty crazy, possibly not even integrable, but I haven't been able to prove that. Any insights?
Did you see this article?
http://mathdl.maa.org/images/upload_library/22/Ford/PaulBYale.pdf
It's a very readable analysis of complex automorphisms. His theorem 4 says that any complex automorphism other than the identity and complex conjugation must be discontinuous.
(edit)
It occurs to me that there's an easy proof. Any automorphism f must fix the rationals Q. That's because f(1) = 1 and so for any natural n, f(n) = f(1 + ... + 1) = n*f(1) = n.
And n*f(1/n) = f(1/n) + ... + f(1/n) = f(1/n + ... + 1/n) [n-times] = f(n/n) = f(1) = 1. So f(1/n) = 1/n.
Then for m/n rational we have f(m/n) = f(1/n + ... + 1/n) [m times] = m*f(1/n) = m/n.
So f fixes the rationals. Any continuous function on the reals is determined by what it does to the rationals, so if f is continuous it fixes the reals. But the only complex automorphisms that fix the reals are the identity and conjugation. So those are the only possible continuous automorphisms, and the rest (given by AC) are discontinuous.
ps better throw in f(-1) = -1 so you can get to the negative rationals. f(-1)*f(-1) = f(1) = 1 so f(-1) must be either 1 or -1. But f(1) = 1 and f is injective so f(-1) must be -1.
There are none besides the identity. To see this, note that an automorphism of C will fix Q. So a continuous automorphism of C will fix R (because Q is dense in R), and consequently will be either the identity or complex conjugation. And only the former is (complex) differentiable.
An alternative way to see this is to note that any differentiable automorphism of the plane is in particular a biholomorphism C->C so must be of the form z->az+b for some a,b in C with a nonzero (a cute exercise). The only such map that's a ring homomorphism is the one with a=1 and b=0 (another cute exercise).
FAQ: Differentiable Automorphisms of ℂ
What are differentiable automorphisms of ℂ?
Differentiable automorphisms of ℂ are functions that are both differentiable and bijective on the complex plane. In other words, they are complex functions that can be inverted and have continuous derivatives.
What is the significance of studying differentiable automorphisms of ℂ?
Studying differentiable automorphisms of ℂ is important in complex analysis and geometry. They have many applications in fields such as topology, differential equations, and physics.
What are some examples of differentiable automorphisms of ℂ?
Some examples of differentiable automorphisms of ℂ include polynomial functions, exponential functions, and trigonometric functions. These functions are widely used in mathematics and have many important properties.
How are differentiable automorphisms of ℂ related to the concept of conformal mappings?
Differentiable automorphisms of ℂ are a special case of conformal mappings, which are functions that preserve angles between intersecting curves. Conformal mappings are important in complex analysis and have many applications in physics and engineering.
What are the main properties of differentiable automorphisms of ℂ?
The main properties of differentiable automorphisms of ℂ include bijectivity, differentiability, and the preservation of angles and lengths. They also have the property of being holomorphic, which means they satisfy the Cauchy-Riemann equations.
