Differential eq of first order and higher degree
In summary, to find the general and singular solution of the equation 3xy=2px2-2p2, p=dy/dx, you can solve for the derivative algebraically and then use Mathematica to find the solutions. One solution is homogeneous, but the others are not. By inspection, it can be seen that y=0 is a singular solution. To find the general solution, divide the equation by x and differentiate, then integrate the resulting factors and check that they work in the original equation.
Suvadip
74
How to proceed to find the general and singular solution of the equation
Question: does $p^{2}$ mean $\displaystyle \left( \frac{dy}{dx} \right)^{ \! 2}$ or $\displaystyle \frac{d^{2}y}{dx^{2}}$?
P^2=(dy/dx)^2
suvadip said:
P^2=(dy/dx)^2
So, in that case, one thing you can try is simply solve for the derivative algebraically first:
\begin{align*}
3xy&=2x^{2} \frac{dy}{dx}-2 \left( \frac{dy}{dx} \right)^{ \! 2} \\
0&=2 \left( \frac{dy}{dx} \right)^{ \! 2}-2x^{2} \frac{dy}{dx}+3xy \\
\frac{dy}{dx} &= \frac{2x^{2} \pm \sqrt{4x^{4}-4(8)(3xy)}}{4} \\
&= \frac{x^{2} \pm \sqrt{x^{4}-24xy}}{2}.
\end{align*}
Unfortunately, either of the resulting DE's,
$$ \frac{dy}{dx}=\frac{x^{2} + \sqrt{x^{4}-24xy}}{2}$$
or
$$ \frac{dy}{dx}=\frac{x^{2} - \sqrt{x^{4}-24xy}}{2}$$
seem rather forbidding. They might be homogeneous, though. Try that.
[EDIT] Never mind about the homogeneous bit. Neither resulting DE is homogeneous.
Mathematica yields $$\{ \{ {{y(x)}\rightarrow
{\frac{-\left( e^{\frac{3\,C(1)}{2}}\,
\left( 3\,e^{\frac{3\,C(1)}{2}} -
{\sqrt{6}}\,x^{\frac{3}{2}} \right) \right) }{3}}}\} ,
\left( 3\,e^{\frac{3\,C(1)}{2}} +
{\sqrt{6}}\,x^{\frac{3}{2}} \right) \right) }{3}}}\} \}.$$
Also, by inspection, you can see that $y=0$ solves the DE. From the looks of the solutions above, this might be a singular solution.
Divide your equation by $x$ and then differentiate. You should find that the new equation factors into two pieces that integrate easily. With these, go back to the original equation and check that they both work (and adjust constants accordingly).
FAQ: Differential eq of first order and higher degree
What is a differential equation?
A differential equation is an equation that relates one or more functions with their derivatives. It describes the relationship between the rate of change of a variable and the variable itself.
What is the difference between a first order and a higher degree differential equation?
A first order differential equation involves one independent variable and its first derivative, while a higher degree differential equation involves higher order derivatives of the independent variable.
What is the purpose of solving a differential equation?
Solving a differential equation allows us to find the function that satisfies the equation and represents a certain physical phenomenon. It also helps us understand the behavior of systems and make predictions about their future states.
What are the common methods for solving differential equations?
The most commonly used methods for solving differential equations include separation of variables, substitution, and using integrating factors. Other methods such as power series and Laplace transforms can also be used for certain types of differential equations.
What are some real-world applications of differential equations?
Differential equations are used in many scientific fields, including physics, engineering, economics, and biology. They are used to model a wide range of phenomena such as population growth, heat transfer, chemical reactions, and motion of objects subject to external forces.
