Differential Equation (Deposit)
In summary, the conversation discusses a person's initial deposit of $500 into a savings account with a 4% interest rate compounded continuously. The person also arranges for $10 to be deposited weekly. The differential equation for the amount on deposit, P(t), is dP/dt = 0.04P + 10, and the solution is P(t) = 500e^0.04t + 10t.
mybingbinghk
A person initially place $500 in a saving account that pays interest at the rate of
4% per year compounded continuously. Suppose the person arranges for $10 per
week to be deposited automatically into the savings account.
(I) Write a differential equation for P (t), the amount on deposit after t years
(assume that “weekly deposits” is close enough to “continuous deposits” so
that we may model the balance with a differential equation.)
Let X(t) be the amount on deposit after t years and dX/dt be the rate of change of the deposit.
dX/dt = 0.04X +480 (480 is the amount of deposit yearly)
and
X(t) = C e^0.04t +480t , where C is a constant
Let X(0) = C =500, then
P(t)=500e^0.04t+480t
Acturally, I dun no the approach is correct or not? Pls Help!
Dear forum post author,
Your approach is mostly correct, but there are a few minor errors. First, the differential equation should be dP/dt, as P is the amount on deposit and not X. Secondly, the amount deposited weekly is $10, not $480 yearly. So the correct differential equation would be:
dP/dt = 0.04P + 10
Also, the initial deposit of $500 should not be included in the equation, as it is already taken into account when we set the initial condition P(0) = 500. So the final solution would be:
I hope this helps! Let me know if you have any further questions.
FAQ: Differential Equation (Deposit)
What is a differential equation?
A differential equation is a mathematical equation that relates a function with its derivatives. It describes the relationship between a function and its rate of change. It is commonly used in physics, engineering, and other scientific fields to model various phenomena.
What is the difference between an ordinary differential equation and a partial differential equation?
An ordinary differential equation involves a single independent variable, while a partial differential equation involves multiple independent variables. This means that the derivatives in a partial differential equation can be with respect to different variables, whereas in an ordinary differential equation, they are all with respect to the same variable.
How are differential equations used in finance?
In finance, differential equations are used to model various financial processes, such as interest rates, stock prices, and option pricing. They are used to predict future values and make decisions based on these predictions.
Can differential equations be solved analytically?
Some differential equations can be solved analytically, meaning that a closed-form solution can be found. However, many differential equations do not have closed-form solutions and require numerical methods to approximate the solution.
What are some real-world applications of differential equations?
Differential equations have a wide range of real-world applications, including modeling population growth, chemical reactions, fluid dynamics, and electrical circuits. They are also used in fields such as economics, biology, and psychology to understand and predict various phenomena.
