Differential Equation Method OF UNDETERMINED COEFF
FahimP
I hav been trying to solve this differential equation by Method of Undetermined Coefficients for a long time.
y"-2y'-3y=-3te^(-t) ......
We are supposed to guess a solution then differentiate and go from there. I guessed
y = (At + B)e^(-t) .... but this does not work. ... can someone help me on this ... I have also tried y = Ae^(-t) but this also doesn't work. Is it possible the book answer is wrong ?
You first need to solve the homogeneous equation. What solution do you get to that?
Of course it's possible the book is wrong. It is also possible that you are wrong. You shouldn't have to "guess" what to try if you have the complementary solution.
I suggest you re-check your work for Ae-t. And if you get an answer you can always check it for yourself by plugging it into the DE.
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
