Differential Equation, Separable, I believe
In summary, a unique solution was found for the given differential equation, with the solution being y^3=x-lnx+C. This was obtained by integrating the equation and substituting in the given value of y(e)=1.
Marylander
Haven't done one of these in awhile and I was looking for a place to make sure I was doing it right. Hopefully one of you can take the time to look it over?
Find the unique solution of the differential equation (3y^2)x(dy/dx)-x+1=0 for which y(e)=1
None.
(3y^2)dy=((x-1)/x)dx
Integrate
y^3=x-lnx+C
Substitute in for unique solution
1^3=e-ln(e)+C
2-e=C
Welcome to PF!
Hi Marylander ! Welcome to PF! :smile:
(try using the X2 tag just above the Reply box :wink:)
Integrate
y^3=x-lnx+C
1^3=e-ln(e)+C
2-e=C
Looks good! :biggrin:
Didn't think to. Too used to not having it.
Good, thanks for checking.
FAQ: Differential Equation, Separable, I believe
1. What is a differential equation?
A differential equation is a mathematical equation that relates a function with its derivatives. It describes how a certain quantity changes over time or in relation to other variables.
2. How do you solve a separable differential equation?
To solve a separable differential equation, you must first separate the variables on different sides of the equation. Then, you can integrate both sides to find the general solution. Finally, you can use initial conditions to find the particular solution.
3. What is the difference between an ordinary and a partial differential equation?
An ordinary differential equation involves only one independent variable, while a partial differential equation involves multiple independent variables. Ordinary differential equations are used to describe a single variable changing over time, while partial differential equations are used to describe multiple variables changing simultaneously.
4. What are some real-life applications of differential equations?
Differential equations are used in many fields, including physics, engineering, economics, and biology. They are used to model and understand various phenomena such as population growth, chemical reactions, and electric circuits.
5. Why are separable differential equations helpful?
Separable differential equations are helpful because they can be solved using integration, which is a well-known mathematical technique. This makes them easier to solve compared to other types of differential equations, allowing for the quick and accurate modeling of real-life phenomena.
