Differential Equation Substitution
In summary, the homework statement states that x\frac{dy}{dx} = y + \sqrt{x^{2} - y^{2}}, x > 0. The attempt at a solution is that x\frac{dy}{dx} = y + \sqrt{x^{2} - y^{2}}. xdy = (y + \sqrt{x^{2} - y^{2}})dx, y = ux, u = \frac{y}{x} and dy = udx + xdu. x[udx + xdu] = (ux + \sqrt{x^{2} - u^{2}x^{2}})dx, xud
KillerZ
116
Solve the given differential equation by using an appropriate substitution.
[tex]x\frac{dy}{dx} = y + \sqrt{x^{2} - y^{2}}[/tex], x > 0
[tex]xdy = (y + \sqrt{x^{2} - y^{2}})dx[/tex]
[tex]y = ux[/tex]
[tex]u = \frac{y}{x}[/tex]
[tex]dy = udx + xdu[/tex]
[tex]x[udx + xdu] = (ux + \sqrt{x^{2} - u^{2}x^{2}})dx[/tex]
[tex]xudx + x^{2}du = uxdx + x\sqrt{1 - u^{2}}dx[/tex]
[tex]\frac{du}{\sqrt{1 - u^{2}}} = \frac{dx}{x}[/tex]
[tex]\frac{du}{\sqrt{1 - u^{2}}} - \frac{dx}{x} = 0[/tex]
[tex]\int\frac{du}{\sqrt{1 - u^{2}}} - \int\frac{dx}{x} = 0[/tex]
[tex]sin^{-1}(u) - ln|x| = ln|c|[/tex]
[tex]sin^{-1}(\frac{y}{x}) - ln|x| = ln|c|[/tex]
[tex]e^{sin^{-1}(\frac{y}{x})} - x = c[/tex]
Hi KillerZ,
Look perfect to me except the very end. You have:
[tex]
arcsin(u) - ln|x| = ln|c|
[/tex]
the next step isn't quite right, it should go:
[tex]
arcsin(u) = ln|x| + ln|c|
[/tex]
[tex]
arcsin\left(\frac{y}{x}\right) = ln|cx|
[/tex]
[tex]
e^{arcsin\left(\frac{y}{x}\right)} = cx
[/tex]
but other than that its perfect, I think you'll probably realize the mistake when you see, just a momentary lapse of judgement. I will say you didn't really need to do this
[tex]
[/tex]
in fact its usally best to keep the integration of different variables on different sides, just as you did in you step before this:
[tex]
\int \frac{1}{\sqrt{1 - u^{2}}} \ du \ = \ \int \frac{1}{x} \ dx
[/tex]
I suppose the mistake at the end is a perfect example of why. Have fun KillerZ :D
From this line
[tex]
[/tex]
if you raise both sides to e then you need to use
ea+b=ea*eb
Ok thanks I just messed up my log rules.
FAQ: Differential Equation Substitution
What is a differential equation substitution?
A differential equation substitution is a method used in solving differential equations by substituting a new variable or function in place of the original variable.
Why is differential equation substitution useful?
Differential equation substitution can help simplify complex equations and make them easier to solve. It can also help find solutions that may not be apparent using traditional methods.
What are some common substitution techniques used in solving differential equations?
Some common substitution techniques include trigonometric substitutions, power substitutions, and variable transformations.
Are there any limitations to using differential equation substitution?
Yes, there are limitations to using differential equation substitution. It may not always work for every type of differential equation and can sometimes lead to difficult or unsolvable integrals.
Can differential equation substitution be applied to real-world problems?
Yes, differential equation substitution can be applied to real-world problems in various fields such as physics, engineering, and economics. It can help model and predict the behavior of systems and phenomena.
