Differential equation that describes the voltage with respect to time
The discussion focuses on analyzing an RLC circuit in series and deriving the differential equation for voltage over time. Participants clarify that the same voltage equations apply, such as VsubC = q/C, VsubL = LI', and VsubR = IR, despite the circuit being in series rather than parallel. The key distinction is that, in a series circuit, the voltage across all components remains constant at any given time. Additionally, the natural frequency of oscillation and the damping constant can be calculated similarly for both configurations. Understanding these principles is essential for solving the homework problem effectively.
DustyGeneral
In class we discussed RLC circuits in series. My homework problem, however, has me analyzing an RLC circuit in series.
a) Write the differential equation that describes the voltage with respect to time.
b) Find the natural frequency of oscillation and the damping constant of the circuit.
I know that because they are connected in parallel they all have the same voltage across them, and because we are studying damped harmonic oscillators that the equation should resemble that of a damped harmonic oscillation.
Do the same aspects of a series circuit apply? For example:
VsubC = q/C
VsubL = LI'
VsubR = IR
or are they completely different for a parallel? I just need a push to get on the right track.
I guess you meant "parallel" in that last sentence.
VsubC = q/C
VsubL = LI'
VsubR = IR
These equations still apply, they are completely general. The difference with the series case is of course that now the voltage across all elements is the same at any value of t.
