PatsyTy
- 30
- 1
<<Moderator note: Missing template due to move from other forum.>>
Good afternoon. I'm trying to solve a differential equation with bessel function solutions. I am trying to solve
\begin{equation*}
y''(x)+e^{2x}y(x)=0
\end{equation*}
using the substitution ##z=e^x##. The textbook this problem is from (Mathematical Methods in the Physical Sciences, Third Edition) also includes that a differential equation in the form
\begin{equation}
y''+\frac{1-2a}{x}y'+\Big[(bcx^{c-1})^2+ \frac{a^2-p^2c^2}{x^2}\Big]y=0
\end{equation}
has a the solution
\begin{equation}
y=x^aZ_p(bx^c)
\end{equation}
I believe that I need to use this to solve the problem.
Using this substitution suggested in the problem I then have ##x=ln(z)## and I solve the derivatives of the functions of ##y(x)## in terms of a new function ##y(x)=w(ln(z))##.
\begin{equation*}
y(x)=w(ln(z)) \\
y'(x)=\frac{w'(ln(z))}{z} \\
y''(x)=\frac{w''(ln(z))-w'(ln(z))}{z^2}
\end{equation*}
Doing the substitution I get
\begin{equation*}
\frac{w''}{z^2}-\frac{w'}{z^2}+z^2w=0
\end{equation*}
multiplying through by ##z^2## to get rid of the denominators gives me
\begin{equation*}
w''-w'+z^4w=0
\end{equation*}
I then compare this to the differential equation of form
\begin{equation}
w''+\frac{1-2a}{z}w'+\Big[(bcz^{c-1})^2+ \frac{a^2-p^2c^2}{z^2}\Big]w=0
\end{equation}
and by inspection get the values for ##a##, ##b##, ##c## and ##p##
\begin{equation*}
1-2a=-1 \rightarrow a=1 \\
(bc)^2=1 \rightarrow b= \frac{1}{c} = \frac{1}{3} \\
2c-2 = 4 \rightarrow c=3 \\
a^2-p^2c^2=0 \rightarrow p= \frac{1}{3}
\end{equation*}
I then go ahead and put these values into the solution ##w=z^aZ_p(bz^c)## and then substitute ##z=e^x## back in and yet a solution of
\begin{equation*}
y=e^xZ_{1/3}\Big(\frac{1}{3}e^{3x}\Big)=e^x\Big(AJ_{1/3}\big(\frac{1}{3}e^{3x}\big)+BN_{1/3}\big(\frac{1}{3}e^{3x}\big)\Big)
\end{equation*}
where ##A## and ##B## are arbitrary constants.
If however I use a computer system to solve the D.E it gives a solution of
\begin{equation*}
y(x)=A J_0\left(\sqrt{e^{2 x}}\right)+B N_0\left(\sqrt{e^{2 x}}\right)
\end{equation*}
I do not believe these are equal and am unsure how to check. Also I am unsure if this is even the correct method for solving D.E with Bessel function solutions as I haven't seen an example using substitution and am having a hard time finding other resources on the method given in the text. Is there another method for solving D.Es with Bessel function solutions? Also is there a name for the method used above so I can try to find more resources on it?
Thanks for any help you can offer, I do appreciate it!
Edit: Also I just realized this is a homework question and is posted in the wrong forum. Miscellaneous question is how can I get this post switched to the correct form? Sorry about this!
\begin{equation*}
y''(x)+e^{2x}y(x)=0
\end{equation*}
\begin{equation}
\end{equation}
has a the solution
\begin{equation}
y=x^aZ_p(bx^c)
\end{equation}
\begin{equation*}
y(x)=w(ln(z)) \\
\end{equation*}
\begin{equation*}
\end{equation*}
\begin{equation*}
w''-w'+z^4w=0
\end{equation*}
\begin{equation}
\end{equation}
\begin{equation*}
\end{equation*}
\begin{equation*}
\end{equation*}
\begin{equation*}
\end{equation*}
