Differential Equation's: A popular solving method
In summary: But yes, the exponential method is a common technique for solving linear differential equations with constant coefficients. It doesn't always work, but it works in many cases.In summary, the speaker has recently enrolled in a maths module involving differential equations and is confused about a method of solving them. The method involves defining the initial function as e^{mx}, differentiating and substituting, and using the quadratic equation to solve. This method involves an educated guess that the solution is an exponential function and is commonly used for linear differential equations with constant coefficients, but may not always work.
AbedeuS
133
Hey, I've recently enrolled in a maths module involving a lot of differential equations, most of the material is all fine and dandy, but I get somewhat confused at this method of solving them.
Scenario
Solve:
[tex]\frac{d^{2}y}{dx{2}} + 2\frac{dy}{dx} + 3y[/tex]
So then there's this technique we were taught to use, where we define the initial function as just [tex]e^{mx}[/tex] then differentiate and substitute and stuff, as such:
[tex]\frac{d^{2}e^{mx}}{dx^{2}}+2\frac{d e^{mx}}{dx}+3e^{mx}[/tex]
To give:
[tex]m^{2}e^{mx}+2me^{mx}+3e^{mx}[/tex]
Then:
[tex]e^{mx}(m^{2}+2m+3)[/tex] and so on and so fourth through quadratic equations and such.
But what am I technically doing, am i just "Guessing" that the origional function was an exponential with a coefficiant on the power, rather than the "True" form of the function instead of just differentiating the origional function?
Or is this method usually employed when the initial function is not known (or is too complex) and the exponential method is just a nice way of dealing with it? Does it always work?
Thanks
-Abe
Mathematics news on Phys.org
Scenario
Solve:
Technically speaking, there's nothing to solve here -- this isn't an equation.
Presumably you want to solve ##\frac{d^{2}y}{dx{2}} + 2\frac{dy}{dx} + 3y = 0##
To give:
Then:
Yes, you're taking an educated guess that the solution is an exponential function of the form ##y = e^{mx}##, and seeing where that guess leads you.
The whole point of solving differential equations is that you don't know the function that satisfies the diff. equation, so you can't just differentiate the "original" function" -- you don't know what it is.
Again, you never know what the solution function is.
FAQ: Differential Equation's: A popular solving method
What is a differential equation?
A differential equation is a mathematical equation that relates a function to its derivatives. It describes the rate of change of a system over time and is commonly used to model physical, biological, and economic phenomena.
What is the difference between an ordinary and partial differential equation?
An ordinary differential equation (ODE) involves a single independent variable, whereas a partial differential equation (PDE) involves multiple independent variables. A PDE can be thought of as an extension of an ODE, where the solution is a function of two or more variables.
What is the most common method for solving differential equations?
The most common method for solving differential equations is using analytical methods, such as separation of variables or integrating factors. These methods involve finding an exact solution in the form of a function, rather than an approximation.
What is the role of initial conditions in solving differential equations?
Initial conditions are values given for the dependent variable and its derivatives at a specific point in time. They are essential for solving differential equations because they help determine the particular solution that satisfies the given conditions.
How are differential equations used in real-world applications?
Differential equations are used in a variety of fields, including physics, engineering, and economics, to model and predict the behavior of systems over time. They can help us understand and make predictions about complex systems, such as the growth of a population or the movement of objects under the influence of forces.
