Differential Equations and Circuits
In summary, the book justified grouping the I term with the dI, but I don't understand why the L, V, and R terms are placed as they are? Can you get the same result if they were not arranged in this way?
nikki__10234
So, I'm learning how to solve LR, RC, LC etc. types of circuits using differential equations. I understand how to do the math with differential equations, but I am confused as to why the variables are split in the way they are.
For example, for an LR circuit you have the equation
L(dI/dt)+RI=V
and then the book integrates both sides:
∫(dI/(V-IR))=∫(dt/L)
and so on...
It is justified to group the I term with the dI, but I don't understand why the L, V, and R terms are placed as they are? Could you get the same result if they were not arranged in this way since the integral is not being taken in terms of V, R or L?
welcome to pf!
hi nikki! welcome to pf! :smile:
nikki__10234 said:
L(dI/dt)+RI=V
and so on...
the V has to stay with the IR …
can you see any way of getting the IR over onto the LHS (with the dI), without the V coming with it?​
but the L could go either side
L(dI/dt)+RI=V
and so on...
The only requirement is that any variables which actually vary in the range of integration stay inside an integral, but it will help if it varies as a function of the variable of integration with which it is placed.
E.g. if L = L(t) then it would best be placed in the integral .dt as above, whereas if R is a constant then you could just as easily write
∫(dI/(V/R-I))=R∫(dt/L)
OTOH, if V = V(t) it's going to get tricky ;-).
FAQ: Differential Equations and Circuits
1. What are differential equations and how are they used in circuits?
Differential equations are mathematical equations that involve rates of change and are used to describe the behavior of dynamic systems. In circuits, differential equations are used to model the relationship between the input voltage, current, and the output voltage, current, and how they change over time.
2. What is the difference between a linear and non-linear differential equation in circuit analysis?
A linear differential equation is one in which the dependent variable and its derivatives appear only in a linear form. This means that the output is directly proportional to the input. Non-linear differential equations, on the other hand, involve terms with powers and products of the dependent variable and its derivatives, making the relationship between output and input more complex.
3. How do you solve differential equations in circuit analysis?
There are several methods for solving differential equations in circuit analysis, including using analytical techniques such as separation of variables or Laplace transforms, or using numerical methods such as Euler's method or Runge-Kutta methods. The method used will depend on the complexity of the circuit and the desired level of accuracy.
4. Can differential equations be used to analyze both AC and DC circuits?
Yes, differential equations can be used to analyze both AC (alternating current) and DC (direct current) circuits. However, the equations and methods used may differ depending on the type of circuit and the input signal. For example, AC circuits may involve the use of complex numbers and phasors, while DC circuits typically use real numbers.
5. What are some real-world applications of differential equations in circuit analysis?
Differential equations are used in circuit analysis to design and analyze a wide range of electrical systems, from simple circuits used in electronics to complex power systems used in large-scale industries. They are also used in the development of electronic devices such as computers, smartphones, and medical equipment. Additionally, differential equations are essential in understanding and predicting the behavior of electric motors, generators, and transmission lines in power systems.
