MHB Differential Equations - Bernoulli equation
ajkess1994
Afternoon, anyone that would like to take a look at this Differential Equation problem it would be very helpful. I have tried separating the problem, but I am only working with one known term.
Consider the logistic equation
$$\dot{y}=y(1-y). $$
(a) Find the solution satisfying $y_1(0)=6$ and $y_2(0)=−1. $
$y_1(t)= ?$
$y_2(t)= ?$
(b) Find the time $t$ when $y_1(t)=3. $
$t= ?$
(c) When does $y_2(t)$ become infinite?
$t= ?$
[y˙=y(1−y)] NOTICE: There is a small dot above the first y term, NOT off to the side
(a) Find the solution satisfying y1(0)=6 and y2(0)=−1.
y1(t)= ?
y2(t)= ?
(b) Find the time t when [y1(t)=3].
t= ?
(c) When does y2(t) become infinite?
t= ?
To get you started: This is a Bernoulli differential equation. You can see the solution method here.
-Dan
Or another approach:
\begin{align*}
\dot{y}&=y(1-y) \\
\int\frac{dy}{y(1-y)}&=\int dt \\
\int\frac{dy}{y}-\int\frac{dy}{y-1}&=t+C \\
\ln|y|-\ln|y-1|&=t+C \\
\ln\left|\frac{y}{y-1}\right|&=t+C \\
\frac{y}{y-1}&=Ce^t \\
&\vdots
\end{align*}
You can solve for $y$ from here.
Thank you Dan
- - - Updated - - -
Thank you Ackbach
There is the following linear Volterra equation of the second kind $$ y(x)+\int_{0}^{x} K(x-s) y(s)\,{\rm d}s = 1 $$ with kernel $$ K(x-s) = 1 - 4 \sum_{n=1}^{\infty} \dfrac{1}{\lambda_n^2} e^{-\beta \lambda_n^2 (x-s)} $$ where $y(0)=1$, $\beta>0$ and $\lambda_n$ is the $n$-th positive root of the equation $J_0(x)=0$ (here $n$ is a natural number that numbers these positive roots in the order of increasing their values), $J_0(x)$ is the Bessel function of the first kind of zero order. I...
Are there any good visualization tutorials, written or video, that show graphically how separation of variables works? I particularly have the time-independent Schrodinger Equation in mind. There are hundreds of demonstrations out there which essentially distill to copies of one another. However I am trying to visualize in my mind how this process looks graphically - for example plotting t on one axis and x on the other for f(x,t). I have seen other good visual representations of...
