MHB Differential equations stability
Harambe1
A one-dimensional dynamical system is given by
$x′ = f(x), t \in [0,+\infty)$,
where $f : \mathbb{R} \to \mathbb{R}$ is the smooth function defined as follows:
$$f(x) = \begin{cases}
x^4 \sin \left(\frac{1}{x}\right) & x \neq 0\\ 0 & x = 0.
\end{cases}.$$
Find all the equilibrium points and determine the stability properties of each equilibrium point.
I've managed to find all the equilibrium points and their stability properties (although using the derivative test I'm not sure if less than zero implies 'stable' or 'asymtopically stable') with the exception of zero. I'm struggling to formally prove its stability using the definition:
The equilibrium point $p \in \mathbb{R}$ is stable if for all $\varepsilon > 0$ there exists a $\delta > 0$ such that $\|x(t)-p\| \leq \delta$ whenever $\|x(t)-p\| \leq \varepsilon$ for all $t \geq t_0 \geq 0$.
I'm not really sure where to start with choosing epsilon or delta or how to use these. Thanks for any tips.
I think you have not quoted the definition of stability correctly for your application. It's looking like you're trying to apply Lyapunov stability:
Given the DE $\dot{x}=f(x)$, and solution $x=\varphi(t,p)$, a point $q$ is stable if given $\varepsilon > 0$, there is a $\delta > 0$ such that $\|\varphi(t,p)-q\|<\varepsilon$ for all $t>t_0$ and for all $p$ such that $\|p-q\|<\delta$. The idea in my mind is this: if you start the system close enough to a stable equilibrium point, then the system stays in an envelope about that equilibrium point for all time after the initial time.
Now your equilibria are:
$$x=0, \; \frac{1}{n\pi}, \; \forall \, n\in\mathbb{Z}.$$
I would do the $\dot{x}$ versus $x$ plot as done in http://www.math.psu.edu/tseng/class/Math251/Notes-1st%20order%20ODE%20pt2.pdf. You just draw arrows in the various regions, corresponding to whether you're above or below the $x$ axis. When you're above, you draw arrows to the right, and when you're below, draw them to the left. If an equilibrium has arrows on both sides going into it, you're stable. If going out of it, you're unstable. If the arrows are going through it, then you're neither unstable nor stable, but semistable (stable from one direction only). Does that make sense?
Another way of thinking about it is this: if $f'(q)<0$ at equilibrium point $q$, then it's stable. If $f'(q)>0$ at equilibrium point $q$, then it's unstable. If $f'(q)=0$, then $q$ is neither.
Thanks for the reply.
I'm not really sure how I would go about drawing a direction field for this particular function so have opted to use the "If $f'(q)>0$ at equilibrium point $q$, then it's unstable. If $f'(q)=0$, then $q$ is neither." Although having obtained $f'(q)=0$ using the equilibrium q=0, the test fails. As I also am unable to sketch the direction field is it possible to use the definition to prove stability at q=o (by choosing an arbitrary epsilon?)
Thanks again.
