Nubcakes
- 7
As the name suggest, this problem is an undetermined coefficients problems where variation of parameters is necessary to solve. As with my previous question; This is not a homework problem, but it is out of the textbook so I figured this would be the appropriate place to ask if I am doing it correctly.
Here is the initial problem where one is asked to find the general solution;
I know there are at least 4 different approaches to this problem, but nearly all will not work well on other similar problems. However, from what I can understand the "Variation of Parameters" technique can be used to solve almost any differential Equation problem in this format so long as you do not encounter an impossible-to-solve integral EXA:{ln(ln(x))}
That being said; here is my attempt at the problem using "Variation of Parameters";
Simple question; Did I do it right? If not where did I screw up?
