Why Do Solutions to y'' + a²y = 0 Include Complex Conjugates?
In summary, the general solution of the second order differential equation y'' + a^2y = 0 is given by y = A cos ax + B sin ax, where A and B are arbitrary constants. This is due to the fact that the characteristic equation has complex roots which come in pairs and can be written as linear combinations of the functions cos(ax) and sin(ax). This is possible because the solutions of the differential equation form a 2-dimensional vector space over the field of complex numbers.
Unto
128
The general solution of the second order DE
[tex]y'' + a^2y = 0[/tex]
is
[tex]y = A cos ax + B sin ax[/tex]
WTF?
o_O
Someone explain why?
The characteristic equation is r2 + a2 = 0, which has solutions r = +/- ai. This means that the general solution is all linear combinations of {eiax, e-iax} = {cos ax + i sin ax, cos ax - i sin ax). By taking suitable linear combinations of these two complex functions, you can get two real solutions, sin(ax) and cos(ax).
Why does the linear combinations include complex conjugate?
A 1st order differential equation has 1 basic solution, a 2nd order differential equation has 2 basic solutions, a 3rd order differential equation has 3 basic solutions, and so on.
The basic solutions are all of the form erx, where r is a root of the characteristic equation. If the characteristic equation has complex roots, these roots always come in pairs - the complex conjugates. For the sake of convenience, instead of writing e(a + bi)x and e(a - bi)x, we do a little algebra and write these functions as eaxcos(bx) and eaxsin(bx) so that we don't have to mess with imaginary numbers at all.
Yes I understand that, I am proficient with complex numbers.
because the solutions form a 2-dim vector space over the field of complex numbers, so by properties of vector spaces all scalar multiples are elements of said solution space, which in this case would include linear combinations of complex conjugates
FAQ: Why Do Solutions to y'' + a²y = 0 Include Complex Conjugates?
What are differential equations?
Differential equations are mathematical equations that describe the relationship between a function and its derivatives. They are commonly used in fields such as physics, engineering, and economics to model the behavior of systems.
What is the difference between ordinary and partial differential equations?
Ordinary differential equations involve a single independent variable, while partial differential equations involve multiple independent variables. Ordinary differential equations also typically have a unique solution, whereas partial differential equations may have multiple solutions.
What are some real-world applications of differential equations?
Differential equations are used to model a wide range of phenomena in the natural and social sciences, including population growth, chemical reactions, fluid dynamics, and electrical circuits. They are also used in engineering to design and control systems such as bridges, aircraft, and power grids.
How do you solve a differential equation?
The method for solving a differential equation depends on the type of equation. Some common techniques include separation of variables, substitution, and using integrating factors. For more complex equations, numerical methods such as Euler's method or Runge-Kutta methods may be used.
What are initial value problems and boundary value problems?
Initial value problems involve finding a solution to a differential equation that satisfies a given set of initial conditions. Boundary value problems involve finding a solution that satisfies a given set of conditions at different points in the domain. Examples of boundary conditions include specifying the value of the function at a certain point, or specifying the value of the derivative at a certain point.
