Differential Euqation (infinite solutions)
In summary, the conversation discusses the proof of infinitely many solutions to the differential equation x' = x^(1/3) with x(0) = 0. Some solutions are presented, including x = [ (2/3)(t) ]^(3/2) and x = 0, and it is shown that there are infinitely many solutions satisfying the boundary conditions. Different methods of proving this are discussed, and it is ultimately concluded that the equation does indeed have infinitely many solutions.
rad0786
188
Hi, I have a question which asks: Prove that there are infinitly many different solutions to the differential equation x' = x^(1/3) with x(0) =0
Well, I solved the differential equation with the five initial value.
I got:
And I know that x = 0 is also a solution...
Can somebody show me how to show that this differential equation has infinitly many solutions?
I think it only has infinitely many solutions without applying the initial condition. Once you apply this, I don't see where infinitely many more solutions will come from...
No, there are an infinite number of solutions satisfying the boundary conditions. You get others by "patching" the two you have together. For example, take x=[ (2/3)(t-a) ]3/2 for x>= a, 0 for x< a where a can be any real number.
Do you mean [itex]t<a[/itex] and [itex]t\geq a[/itex] ? (As opposed to x)
Anyway I don't think the above solution would work because [itex]x[/itex] as you have given it is a continuous function of [itex]t[/itex], while it has a finite discontinuity in the derivative at [itex]t=a[/itex]. If I look at the original ODE,
[tex]
x^{\prime} = x^{1/3}
[/itex]
If [itex]x[/itex] is continuous, then so is [itex]x^{\prime}[/itex]. Probably you would have to choose the range of [itex]t[/itex] for these functions so that you have a finite discontinuity in [itex]x[/itex], to match the discontinuity in the derivative... ? I'm not so sure about this though. Would a derivative even be defined then?
A finite discontinuity? What on Earth is that? The deriviative of the function given by Halls is not discontinuous, unless you think the square root of 0 is not 0.
Yes, you're right, I was picturing the wrong function as it was going to a - the derivative is in fact continuous everywhere. It's a nice solution, although you would require that [itex]a\geq 0[/itex].
Matt, maybe you know a finite discontinuity as a jump discontinuity.
No, I just know that as a discontinuity. Why would anyone make up that definition? Presumably you have that, say 1/x for x>0 and 0 otherwise as an infinite discontinuity (and that isn't a 'jump'). Seems a strange thing to bother to name.
Well i am confused out of my mind.
Our textbook SUCKS and has no solutions to it's practice problems.
My prof. posted her soultions, but it makes no sense...
ill post back here soon..
Yes, it does seem pointless in naming them, I don't see any benefit from their definitions. And yes 1/x for x>0, 0 otherwise, would be an infinite discontinuity.
rad: What are you confused with?
I'm confuzed with the question "Prove that this differential equation had infinite solutions"
How on Earth do you prove that?
I'll have to read through the above posts and take sometime to think things through...it's late now and I'm off to sleep..
Well Halls' solution shows you that this equation has infinitely many solutions. For every [itex]a[/itex] that you pick, you will have a solution which satisfies your initial condition. Since [itex]a[/itex] is an arbitrary constant, you have inifinitely many choices of [itex]a[/itex], and so infinitely many solutions.
FAQ: Differential Euqation (infinite solutions)
What are differential equations?
Differential equations are mathematical equations that describe the relationship between a function and its derivative. They are used to model and solve a wide range of real-world problems in fields such as physics, engineering, and economics.
What is the difference between a differential equation with infinite solutions and one with a unique solution?
A differential equation with infinite solutions means that there are multiple functions that satisfy the equation, while a differential equation with a unique solution has only one function that satisfies it. In other words, there are infinitely many possible solutions for the former, while there is only one solution for the latter.
Can a differential equation with infinite solutions still be useful in real-world applications?
Yes, a differential equation with infinite solutions can still be useful in real-world applications. In some cases, it may be more practical to have multiple solutions that can be used to model and solve a problem, rather than just one unique solution. Additionally, some physical systems may have multiple possible solutions due to uncertainties or variations in initial conditions.
How can I determine if a differential equation has infinite solutions?
To determine if a differential equation has infinite solutions, you can use techniques such as separation of variables, substitution, or undetermined coefficients to solve the equation. If the resulting solution contains arbitrary constants, then the equation has infinite solutions.
Can the number of solutions for a differential equation change?
Yes, the number of solutions for a differential equation can change depending on the initial conditions or parameters in the equation. For example, a differential equation may have one solution for certain initial conditions, but multiple solutions for different initial conditions. Additionally, the number of solutions may change if the equation is modified or if additional constraints are imposed.
