sponsoredwalk
- 533
- 5
*Bit of reading involved here, worth it if you have any interest in, or
knowledge of, differential forms*.
It took me quite a while to find a good explanation of differential forms & I
finally found something that made sense, in a sense. Most of what I've written
below is just asking you to judge it's general correctness, the notation etc..., as
a some of it is based on intuition based on the material I read. At the bottom you'll
see I have an issue with projections & a concern about throwing around minus signs.
Also I can't find a second source that describes forms this way so hopefully someone
will learn something
If anyone find any source with a comparable
explanation please let me know![Cool :cool: :cool:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
A single variable differential 1-form is a map of the form:
[itex] f(x) \ dx \ : \ [a,b] \rightarrow \ \int_a^b \ f(x) \ dx[/itex]
When you take the constant 1-form it becomes clearer:
[itex] dx \ : \ [a,b] \rightarrow \ \int_a^b \ \ dx \ = \ \Delta x \ = \ b \ - \ a[/itex]
Okay, didn't know that's what a form was
Beautiful stuff! In my
favourite kind of notation too!
This looks an awful lot like the linear algebra idea of a linear functional in
a vector space (V,F,σ,I):
[itex] f \ : \ V \ \rightarrow \ F [/itex]
where you satisfy the linearity property.
In more than one variable you can have:
[itex] dx \ : \ [a_1,b_1] \rightarrow \ \int_{(a_1,a_2)}^{(b_1,b_2)} \ \ dx \ = \ b_1 \ - \ a_1[/itex]
[itex] dy \ : \ [a_2,b_2] \rightarrow \ \int_{(a_1,a_2)}^{(b_1,b_2)} \ \ dy \ = \ b_2 \ - \ a_2[/itex]
which leads me to think that the following notation makes sense:
[itex] dx \ + \ dy \ : \ [a_1,b_1]\times [a_2,b_2] \rightarrow \ \int_{(a_1,a_2)}^{(b_1,b_2)} \ \ dx \ + \ dy \ = \ \int_{(a_1,a_2)}^{(b_1,b_2)} \ \ dx \ + \ \int_{(a_1,a_2)}^{(b_1,b_2)} \ dy = \ (b_1 \ - \ a_1) \ + \ (b_2 \ - \ a_2) \ = \ \Delta x \ + \ \Delta y[/itex]
The pull back stuff just "pulls" an integral in x variables "back" to 1
parametrized variable as far as I can see.
If [itex] \overline{a} \ =\ (a_1,a_2)[/itex] & [itex] \overline{b} \ =\ (b_1,b_2)[/itex] then:
[itex] \lambda_1 dx \ + \ \lambda_2 dy \ : \ [a_1,b_1]\times [a_2,b_2] \rightarrow \ \int_{ \overline{a}}^{ \overline{b}} \ \ \lambda_1 dx \ + \ \lambda_2 dy \ = \ \lambda_1 \int_{(a_1,a_2)}^{(b_1,b_2)} dx \ + \ \lambda_2 \int_{(a_1,a_2)}^{(b_1,b_2)} dy = \ \lambda_1 (b_1 \ - \ a_1) \ + \ \lambda_2 (b_2 \ - \ a_2) \ = \ \lambda_1 \Delta x \ + \ \lambda_2 \ \Delta y[/itex]
That's the notable stuff for 1-forms, also that they can be extended to
n dimensions very explicitly with this notation & things don't have to be
constant. The vector parallels (notably Work!) are just jumping out
already!
I'd like to quote the book now:
"Differential 1-forms are mappings from directed line segments to
the real numbers. Differential 2-forms are mappings from oriented
triangles to the real numbers".
So, by this comment what we're doing with a differential 2-form is
finding the area in a triangle. What do you do when you find area's?
Use the cross product! How does the cross product work? It works
by finding the area contained within (n - 1) vectors & expresses it
via a vector in n-space!
Furthermore from what I gather the whole
theory is integration via simplices - p-dimensional triangles, or at least
the general idea is.
So if we have a positively oriented triangle:
Which we denote by [itex] T \ = \ [ \overline{a},\overline{b},\overline{c}][/itex] (This is all done in ℝ² for now)
what is the area of the triangle?
[itex] A \ = \ \frac{1}{2} \cdot b \cdot h \ = \ \frac{1}{2} \cdot ( ( \overline{c} \ - \ \overline{a}) \times ( \overline{b} \ - \ \overline{a}))[/itex]
Just extend it to 3 dimensions for the calculation & you get the result.
If you go from [itex] \overline{a}[/itex] to [itex] \overline{b}[/itex] to [itex] \overline{c}[/itex] you have
which is defined as a positive orientation & if you go from [itex] \overline{a}[/itex] to [itex] \overline{c}[/itex] to [itex] \overline{b}[/itex] you have
[itex] T \ = \ [ \overline{a},\overline{c},\overline{b}][/itex]
which is defined as a negative orientation.
[itex] dx \ dy \ : \ [ \overline{a},\overline{b},\overline{c}] \ \rightarrow \ 6[/itex]
[itex] dx \ dy \ : \ [ \overline{a},\overline{c},\overline{b}] \ \rightarrow \ - 6[/itex]
This is made clearer with the notation:
[itex] dx \ dy \ : \ T \ \rightarrow \ \int_T \ dx \ dy \ = \ \ \frac{1}{2} \cdot ( ( \overline{c} \ - \ \overline{a}) \times ( \overline{b} \ - \ \overline{a}))[/itex]
All of this I think I understand.
The next issue is defining 2-forms in 3 dimensional space. There is
talk of projections and such, I don't quite understand what's going on
though.
The projection of a point (x,y,z) onto the x-y plane is (x,y,0).
The projection of the triangle
[itex] T \ = \ [ \overline{a},\overline{b},\overline{c}] \ = \ [(a_1,a_2,a_3),(b_1,b_2,b_3),(c_1,c_2,c_3)][/itex]
[itex] T \ = \ [ \overline{a},\overline{b},\overline{c}] \ = \ [(a_1,a_2,0),(b_1,b_2,0),(c_1,c_2,0)][/itex].
They say that they will define the differential form [itex]dx \ dy[/itex]
to be the mapping from the oriented triangle [itex]T[/itex] to the
signed area of it's projection onto the x-y plane,
which is the z coordinate of [itex] \frac{1}{2} \cdot ( ( \overline{c} \ - \ \overline{a}) \times ( \overline{b} \ - \ \overline{a}))[/itex]![Confused :confused: :confused:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
That doesn't make much sense, but I read on & see that
[itex] \frac{1}{2} \cdot ( ( \overline{c} \ - \ \overline{a}) \times ( \overline{b} \ - \ \overline{a})) \ = \ ( \int_T dy \ dz, \int_T dz \ dx, \int_T dx \ dy)[/itex]
Now, this makes sense in that what is orthogonal to dx dy is something
in the z coordinate, and what is orthogonal to dy dz is in the x
coordinate etc... But what does that justification paragraph actually say?
I get the feeling it's an insight I should know about, I don't understand
what's going on with the projections. I think that if I did I would have
predicted the integrals in the coordinates the way it's set up there!
Let me quote the actual paragraph in it's entirety just in case:
Also, based on all of that writing I still don't know why dx dy = - dy dx![Frown :frown: :frown:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
What I mean by this is that after all that good work he just defines
dx dy to be the area of that triangle, I think you can see my problem
lies with the projection issues. I think if I understand what's going on
with the projections I'll get it. Please don't just resort to telling me that
[itex] \ihat{k} \ \times \ \ihat{j} \ = \ \ihat{i}[/itex]
I mean I can justify things as they stand in a sense because I know dy dx
goes to the z dimension with the negative of what happens when dx dy goes
to the z-axis (from the algebra involved in the cross product derivation
via the orthogonality of the dot product) but I still feel like something
is missing or suspect. I don't feel very confident about this because of orientation:
[itex] dx \ dy * \ : \ [ \overline{a},\overline{c},\overline{b}] \ \rightarrow \ - 6[/itex]
I mean dx dy = 6 = - (-6) = - dx dy *, I just feel a little iffy about
throwing out minus signs to justify anti-commutativity issues! I don't
think that dx dy = 6 = - dy dx = dx dy* = - (-6), but that could just be
confusion.
So, the question is just about the general correctness of what I wrote
& then the issue of projections, I couldn't just post a question about
projections because I'm not 100% sure my take on the theory that
leads up to this is 100% accurate (I think it is though!) & to be quite
honest seeing as I have spent ages trying to find someone who would
explain the theory in this way, but having been unable to find anyone
who would, makes me think very few people view this subject this way
& as such would love to see how different it is for someone who takes
the axiomatic, anti-commutative, definitions that are found in nearly all
of the books on google. If this is/isn't new please let me know anyway
(and help if possible
)! ![Big Grin :biggrin: :biggrin:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
![Blushing :blushing: :blushing:](https://www.physicsforums.com/styles/physicsforums/xenforo/smilies/oldschool/blushing.gif)
already!
though.
We define the differential 2-form [itex]dx \ dy[/itex] in 2 dimensional
space to be the mapping from an oriented triangle [itex] T \ = \ [ \overline{a},\overline{b},\overline{c}][/itex]
to the signed area of it's projection onto the x,y plane, which is the z
coordinate of
[itex] \frac{1}{2} \cdot ( ( \overline{c} \ - \ \overline{a}) \times ( \overline{b} \ - \ \overline{a}))[/itex].
Similarly, [itex]dz \ dx [/itex] maps this triangle to the signed area
of it's projection onto the z,x plane which is the y coordinate of
The 2-form [itex]dy \ dz [/itex] maps this triangle to the signed area
of it's projection onto the y,z plane, the x coordinate of
"Second Year Calculus - D. Bressoud".
confusion.
![Red Face :redface: :redface:](https://www.physicsforums.com/styles/physicsforums/xenforo/smilies/oldschool/redface.gif)
