Differential geometry : Tangent vector & reparameterization
In summary: AND complex numbers; where csgn = complex signum.The arc length function in your relevant equations gives the arc length in terms of a parameter t.IOW, ##\int_0^t 5 \sqrt{\cosh^2(w)} dw## is the reparameterization of the tangent vector.
Schwarzschild90
113
Problem statement uploaded as image.
Arc-length function
Tangent vector:
r=-sinh(t), cosh(t), 3
Now, I just need to reparameterize it using arclength and verify my work is unit-speed. Will someone give me a hint? Should I use the arc-length function to accomplish this.
Arc-length function
Tangent vector:
What is preventing you from trying it for yourself?
Likes Schwarzschild90
It's that I have no means of checking the solution, so before I invest in it, I would like to know if my method is correct (assuming that I integrate correctly).
Arc-length function
Tangent vector:
This isn't the tangent vector.
In future posts, please show more of your work. What you have here just barely qualifies as a problem attempt.
Tangent vector
Now, compute the norm of the tangent vector:
Using this, make the following substitution
How do I compute the arclength, without knowing the range? For example [0 <= t <= 2pi]
Another shot at the arc length of the tangent vector
[itex]\sqrt{(9+9*sinh(t)^2+16*cosh(t)^2)}dt =^*
25 cosh^2(t) =
25 sinh^2(t)+25
[/itex]
* Using a trigonometric identity
PS: csgn is code used specifically by maple. It' not necessarily a mathematical function
25 cosh^2(t) =
25 sinh^2(t)+25
[/itex]
The last expression above is not helpful, but the one before it is helpful. What happened to the square root?
Do you know what it means, though? I've never seen it, but I don't use Maple.
Right, the square root should've been preserved, in the above equation. Here it is, in all of its glory:
[itex]\sqrt{25cosh^2(t)}[/itex]
So, is this equation the reparameterization of the tangent vector?
csgn(x) is the sign function of real AND complex numbers; where csgn = complex signum.
Plot of the 25cosh^2(t) function; the norm of the tangent vector
This is not relevant. The question is what cosh(t) looks like, not its square. You should not even need to do an actual plot; just picture it in your mind.
Plot of [itex]5 \sqrt{cosh(t)}[/itex]
I can picture it in my mind. What am I supposed to "see"?
I get this for the parameterization by arclength of the tangent vector
[itex]int(5*sqrt(cosh(t)^2), t = 0 .. 1) = 5 sinh(1)[/itex]
This is not a parameterization -- it's a number.
As I said before...
FAQ: Differential geometry : Tangent vector & reparameterization
1. What is a tangent vector in differential geometry?
A tangent vector in differential geometry is a vector that is tangent to a curve or surface at a specific point. It represents the direction and rate of change of the curve or surface at that point.
2. How is a tangent vector calculated?
A tangent vector can be calculated by taking the derivative of a curve or surface at a specific point. This can be done using calculus or other mathematical methods.
3. What is reparameterization in differential geometry?
Reparameterization in differential geometry is the process of changing the parameterization of a curve or surface. This can be done by redefining the parameterization function or by using a different set of parameters to describe the curve or surface.
4. Why is reparameterization important in differential geometry?
Reparameterization is important in differential geometry because it allows for the manipulation and transformation of curves and surfaces while preserving their geometric properties. It also allows for easier calculations and analysis of these objects.
5. What are some real-world applications of differential geometry and tangent vectors?
Differential geometry and tangent vectors have many applications in the fields of physics, engineering, and computer graphics. They can be used to model and analyze the motion of objects, calculate the curvature and torsion of curves and surfaces, and generate smooth and realistic animations in computer graphics.
