Differential of a y mixed with x
I can't get a general solution for y without integration, so i can find only a particular solution for y, in terms of x. What i really need is to make a substitution to get an equation like y'=... , so i can integrate it, i think.In summary, the conversation discusses finding the differential of a product using the formula d(uv)=u⋅dv+v⋅du and applying it to the equation xy^2+x^2y=4 to solve for dy. The conversation also touches on implicit differentiation and the use of substitution to get
Karol
1,380
Find dy of ##~xy^2+x^2y=4##
Differential of a product:
$$d(uv)=u\cdot dv+v\cdot du$$
$$2xy~dy+y^2~dx+x^2~dy+2xy~dx=0$$
$$x(2y+x)dy=-(y+2x)dx$$
You miss a y on the RHS.
$$x(2y+x)dy=-y(y+2x)dx$$
$$\frac{dy}{y}=-\frac{y+2x}{2y+x}~\frac{dx}{x}$$
Is there a meaning for ##~\frac{dy}{y}~##?
What type of meaning are you considering? You can see it as ##\frac{1}{y} dy ##.
And what is ##~\frac{1}{y} dy~##? what do i do with it? ##~d(ln~y)=\frac{1}{y} dy##
But the book teaches logs only later
I think to solve your original problem, you want to rearrange it so that you have (dy/dx) = {something}
I have to find ##~\frac{dy}{dx}=f(x)~##, but i have ##~\frac{dy}{dx}=f(x,y)##
I would guess this is a case of implicit differentiation, where you assume y is a function of x. Is that in your book?
Yes, y=f(x) only
Then differentiate the whole expression as a function of x, using the chain rule on y=y(x).
$$2xy\frac{dy}{dx}+y^2+x^2\frac{dy}{dx}+2xy=0$$
$$dy=-\frac{y^2+2xy}{x^2+2xy}~dx$$
Good, but no need to split the dy/dx. Leave it as a single unit and solve for it.
$$\frac{dy}{dx}=-\frac{y^2+2xy}{x^2+2xy}$$
What i can do, and i can't even that, is to integrate, but it's not the point and the book didn't teach it yet.
What else can i do with a derivative which involves y?
I need dy, that is what i was asked, and any dy=f(x)dx
I need to express, find, what is y=y(x)
Sorry, then do split into dy and dx parts.I am not clear, just what is your goal here, to find y?
I was asked to find dy
My apologies then, do separate dy and dx and solve for dy.
Now i see that the book's answer is like mine, leaving y undevelopped
" undeveloped"? How so? What is the book's answer?
Thank you scottdave and WWGD
Likes WWGD
Related to Differential of a y mixed with x
1. What is the differential of a y mixed with x?
The differential of a y mixed with x refers to the change in y with respect to a change in x. In other words, it is the rate of change of y in relation to x.
2. Why is the differential of a y mixed with x important?
The differential of a y mixed with x is important because it helps us understand the relationship between two variables and how they affect each other. It is also used in many mathematical and scientific equations to analyze and predict changes in a system.
3. How is the differential of a y mixed with x calculated?
The differential of a y mixed with x is calculated using the derivative function, which involves finding the slope of the tangent line to a curve at a specific point. This can be done using various methods, such as the power rule, product rule, and chain rule.
4. Can the differential of a y mixed with x be negative?
Yes, the differential of a y mixed with x can be negative. This means that the change in y is decreasing as the change in x increases, indicating an inverse relationship between the two variables.
5. How is the differential of a y mixed with x used in real-world applications?
The differential of a y mixed with x is used in various fields, including physics, engineering, economics, and biology. It can help us understand and predict changes in systems and make informed decisions based on the relationship between variables.
