I Differential structure on topological manifolds of dimension <= 3
cianfa72
TL;DR Summary
About the unique smooth structure on topological manifold of dimension less then equal 3
Hi,
From Lee book "Introduction on Smooth Manifolds" chapter 2, every topological manifold (Hausdorff, locally Euclidean, second countable) of dimension less then or equal 3 has unique smooth structure up to diffeomorphism.
A smooth structure on a manifold is defined by a maximal atlas.
So, why diffeomorhpisms are taken in account in the above statement ? It is actually equivalent to the claim that a given topological manifold of dimension less then equal 3 has got an unique maximal atlas.
cianfa72 said:
So, why diffeomorhpisms are taken in account in the above statement ? ...
Because there are different ones, but they are diffeomorphic. You can have two maximal atlases which are incompatible.
Can you give an example of the above statement ? Thanks.
Consider the manifold ##\mathbb R## with a global chart the identity map. Let ##\mathcal A_1## be the maximal atlas of charts compatible with the given chart.
Then consider ##\mathbb R## with one global chart given by the map ##x \mapsto x^3## and ##\mathcal A_2## be the maximal atlas of charts compatible with the given chart.
Likes WWGD and cianfa72
Ok, the map ##x \mapsto x^{1/3}## is a global diffeomorphism between manifolds ##(\mathbb R, \mathcal A_1) \mapsto (\mathbb R, \mathcal A_2)##.
Yet, the transition map between ##\mathcal A_1##'s and ##\mathcal A_2##'s global charts $$x \mapsto x^3$$ is not a diffeomorphism on ##\mathbb R^n## (endowed with its standard smooth structure).
Sorry to resume this thread. Yes the two maximal atlas can be incompatible at ##C^1##-level or beyond, nevertheless by definition they are always ##C^0##-compatible.
Yes, that seems self-evident if you know the definition of a ##C^k## atlas, i.e. a maximal set of homeomorphisms from the open sets of ##M## to ##\mathbb R^n## that are ##C^k## compatible.
What is more interesting I think, is that you can have incompatible smooth structures of a manifold that are nonetheless diffeomorphic or you can have have incompatible smooth structures that are not diffemorphic like the exotic smooth structures discussed in the thread, https://www.physicsforums.com/threa...f-exotic-smoothness-in-and-only-in-4d.936465/
jbergman said:
What is more interesting I think, is that you can have incompatible smooth structures of a manifold that are nonetheless diffeomorphic or you can have have incompatible smooth structures that are not diffemorphic.
Yes, the main point I recognized only recently, is that for the notion of continuity (on which homeomorphisms are grounded on) one can define a pre-existing structure on the manifold itself (i.e. a locally euclidean topology) independently from the definition of an atlas.
On the other hand, for the notion of smooth/differentiability (i.e. differential structure) one can't define such a pre-existing structure on manifolds since it is "lifted" there by the definition of a smooth atlas (as a slogan: no atlas no differential structure on manifolds :wink: ).
Therefore, of course, it might be the case that two differential/smooth structures happen to be incompatible.
Ok. So the next step here would be to show that for one to three dimensional manifolds that they all have a differentiable structure that is unique up to diffeomorphism.
Would someone like to start with the circle?
Likes WWGD and jbergman
Well, we only have ##S^1##, ##\mathbb R## as 1- manifolds. I'm curious as to why there are infinitely many smooth structures for n>3, but only one for Minkowski space time.
Intuitively, thinking of 1d-manifolds as specific subsets of ##\mathbb R^2## with standard topology, it makes sense. However: can we conclude that there isn't any other Hausdorff, second-countable, locally euclidean topology for a 1d topological manifold?
Another interesting result is that there are 4-manifolds that don't allow any differential structure; if the signature of the Intersection form doesn't divide 16. IIRC, Spin structures are also involved.
Edit: Maybe @lavinia knows how to create a 4-manifold with a given signature?
