Differentials and tolerances
In summary: If a 1% error in volume is tolerable, a 0.5% error in the linear measurement is necessary.In summary, the interior diameter of the cylindrical storage tank must be measured with an error that is no more than 0.5% of its true value in order to calculate the tank's volume to within 1% of its true value. This can be determined by considering the error in the linear measurement and its effect on the calculated volume.
OCTOPODES
About how accurately must the interior diameter of a 10-m high cylindrical storage tank be measured to calculate the tank's volume to within 1% of its true value?
[itex]V=\frac{5}{2}\pi l^{2}[/itex], where [itex]V[/itex] is volume and [itex]l[/itex] is diameter.
[itex]dV=5\pi l \ dl[/itex]
I'm really uncertain as to how to go about this problem. What follows is the textbook's method for a similar problem translated into this problem's terms.
We want any inaccuracy in our measurement to be small enough to make the corresponding increment [itex]\Delta V[/itex] in the volume satisfy the inequality
[itex]|\Delta V|\leq\frac{1}{100}V=\dfrac{\pi l^{2}}{40}[/itex].
We replace [itex]\Delta V[/itex] in this inequality by its approximation
[itex]dV=\left(\dfrac{dV}{dl}\right)dl=5\pi l \ dl[/itex].
This gives
[itex]|5\pi l\ dl|\leq\dfrac{\pi l^{2}}{40}[/itex], or [itex]|dl|\leq\dfrac{1}{5\pi l}\cdot\dfrac{\pi l^{2}}{40}=\dfrac{1}{5}\cdot\dfrac{l}{40}=0.005l[/itex].
We should measure [itex]l[/itex] with an error [itex]dl[/itex] that is no more than 0.5% of its true value.
I need some clarification for this solution. Could somebody annotate it, or perhaps write up a more intuitive one?
Your answer is correct. I would tend to start from the other end. V = πl2h/4. If there's a fractional error δ in l, the computed volume will be π(l(1+δ))2h/4 = V(1+δ)2 = V + 2Vδ + Vδ2 ≈ V + 2Vδ. So the fractional error in the volume will be about double that in the linear measurement.
FAQ: Differentials and tolerances
What are differentials and tolerances?
Differentials and tolerances are terms used in the field of engineering and manufacturing to describe the acceptable range of variation for a particular measurement or dimension. Differentials refer to the difference between the maximum and minimum values, while tolerances represent the acceptable amount of deviation from a specified target.
Why are differentials and tolerances important?
Differentials and tolerances are important because they ensure that manufactured products meet the required specifications and standards. They allow for a certain level of variation in the production process without compromising the functionality or quality of the final product.
How are differentials and tolerances determined?
Differentials and tolerances are determined through careful analysis and consideration of various factors such as the intended use of the product, material properties, manufacturing processes, and performance requirements. They may also be based on industry standards and regulations.
What are some common methods for controlling differentials and tolerances?
Some common methods for controlling differentials and tolerances include statistical process control, quality control inspections, and using precision measurement tools. These methods help to identify and correct any variations in the manufacturing process to ensure that the final product meets the required specifications.
What are the consequences of not adhering to specified differentials and tolerances?
Not adhering to specified differentials and tolerances can result in products that do not meet the required standards or perform as expected. This can lead to costly recalls, repairs, and potential safety hazards. It can also damage a company's reputation and credibility in the market.
