Differentiate Fraction: Finding the Derivative of 2/(x+1)
To find the derivative of 2/(x+1), the correct approach involves using the limit definition of the derivative. The initial attempt incorrectly applied the formula and omitted the limit. The corrected expression is 1/h multiplied by the difference of the function values, which simplifies to -2/(x^2 + 2x + 1) as h approaches 0. This result can also be expressed as -2/(x + 1)^2. Understanding these steps is crucial for mastering differentiation techniques.
max0005
Find the first derivate of \frac{2}{x+1}.
Formula: \frac{f(x+h)-f(x)}{h}
\frac{\frac{2}{x+h+1}-\frac{2}{x+1}}{h}
h(\frac{2}{x+h+1}-\frac{2}{x+1})
h(\frac{2(x+1)-2(x+h+1)}{(x+1)(x+h+1)}
h*\frac{-2h}{x^2+xh+2x+h+1}
...How do I go on from here? I should get rid of all h in the denominator, but don't have any clue on how to do that... :(
First off, this is in the wrong forum. Should be in the Calculus and Beyond sub forum.
Second, the formula is wrong. The limit part is missing.
Third, this step:
is wrong. Should be
\frac{1}{h}(\frac{2}{x+h+1}-\frac{2}{x+1})
Third, this step:
is wrong. Should be
Then I'd get
\frac{1}{h}*\frac{-2h}{x^2+xh+2x+h+1}
But I don't understand how to continue..
Cancel a factor of h from top and bottom. Then let h -> 0 and you'll get
<br /> \frac{-2}{x^2+2x+1} = \frac{-2}{(x + 1)^2}<br />
Later, when you learn "shortcuts" (i.e rules of differentiation that will be proven), this second form will look a lot more familiar.
max0005 said:
Then I'd get
\lim_{h \rightarrow 0} \frac{1}{h}*\frac{-2h}{x^2+xh+2x+h+1}
(Fixed the above for you.)
Can you see that something cancels?
EDIT: Never mind, The Chaz beat me to it... :wink:
Ok, got it, thanks! :D
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
