Differentiate with respect to x
In summary: I am still a little unsure about the notation, but I will get used to it.In summary, the correct solution for the derivative of y = 3*cube root 3√(x2-1) is dy/dx = 2x/(x2-1)^(2/3). The book's answer, dy/dx = 3*1/3(x2-1)^-2/3, is incorrect as it is missing the factor of 2x from the chain rule.
lubo
36
Udu/dx + Vdv/dx (wrong as per below)
Chain Rule now used
I have:
Now y = 3*(x2-1)^1/3
let z=x2-1 y= 3(z)^1/3
dz/dx = 2x dy/dz = z^-2/3 = (x2-1)^-2/3
all = dy/dx = dz/dx * dy/dz = 2x*(x2-1)^-2/3 = 2x/(x2-1)^2/3
Instead I have an answer in my book:
which in the end = (x2-1)^-2/3
I believe my answer is correct and it is a typing mistake, but I am not 100% sure.
Thank you for any help in advance.
You didn't use/need the product rule here. You just need the chain rule
[itex]{{dy}\over{dx}} = {{dy}\over{du}}{{du}\over{dx}}[/itex]
where [itex]u = x^2 -1[/itex] and [itex]y(u) = 3u^{1/3}[/itex].
Neither your solution or the books solution is correct, though (are you sure you copied the problem down correctly?). I'm not sure how your last line came to be.
Udu/dx + Vdv/dx not the appropriate formula, but you compensate for this by applying the right one instead of the one you quote
I have:
U=x2-1 v= 3(u)^1/3
du/dx = 2x dv/du = u^-2/3
all = 2x*(x2-1)^-2/3 OK but you then haven't carrie through the whole bracket to the next step= 2x/(x2)^2/3
Seeing the answer that came after I started this post, I already thought the quoted book answer doesn't seem right either. Easiest thing is to restart from scratch.
Pengwuino and Epenguin - I have anotated the chain Rule. Thanks for that. I am sure the question is copied correctly, but I have made it a little more clearer. It is hard getting used to looking at all the stuff needed for x squared as an example.
Also I am getting used to how this site works...
Please have another look and check it again. If it is still no good, could you please post what you think the answer is as I have two and this is the best I have.:smile:
Chain Rule now used
I have:
This is correct, but you should put parentheses around your exponent.
2x*(x2-1)^(-2/3) = 2x/(x2-1)^(2/3)
This answer is incorrect - it's missing the factor 2x that comes from the chain rule.
Thank you. It feels good to have that cleared up.
FAQ: Differentiate with respect to x
What does "differentiate with respect to x" mean?
When we differentiate a function with respect to x, we are finding the rate of change of that function with respect to the variable x. Essentially, we are finding the slope of the function at a specific point on the graph.
Why do we need to differentiate with respect to x?
There are many applications of differentiation, but one of the main reasons we differentiate with respect to x is to solve problems involving optimization and finding maximum or minimum values of a function.
How do we differentiate with respect to x?
The process of differentiation involves using specific rules and formulas to find the derivative of a function. These rules include the power rule, product rule, quotient rule, and chain rule. It is important to understand these rules and practice using them to differentiate with respect to x.
What is the difference between differentiating with respect to x and y?
When we differentiate with respect to x, we are finding the rate of change of a function with respect to the variable x. This means we are looking at how the function changes as we move along the x-axis. When we differentiate with respect to y, we are finding the rate of change of a function with respect to the variable y, or how the function changes as we move along the y-axis.
Can we differentiate with respect to any variable?
Yes, we can differentiate with respect to any variable in a function. However, it is important to note that the rules and formulas for differentiation may differ depending on the variable we are differentiating with respect to. For example, the power rule is used when differentiating with respect to x, while the logarithmic differentiation rule is used when differentiating with respect to y.
