MHB Differentiating $\mathcal{E}$: How to Reach $\dot{x}(m\ddot{x} + kx)$?
The discussion centers on the differentiation of the energy equation $\mathcal{E} = \frac{1}{2}m\dot{x}^2 + \frac{1}{2}kx^2$. Participants clarify that the correct form of kinetic energy includes the square of speed, leading to the derivative $\frac{d\mathcal{E}}{dt} = m\dot{x}\ddot{x} + kx\dot{x}$. The confusion arises from an incorrect initial formulation of energy, which led to a misinterpretation of the derivative. Ultimately, the consensus suggests that the original energy equation in the book contains a typo, necessitating correction for accurate differentiation. This highlights the importance of precise definitions in physics equations.
Dustinsfl
$\mathcal{E} = \frac{1}{2}m\dot{x} + \frac{1}{2}kx^2$
The derivative is
\frac{d\mathcal{E}}{dt} = \frac{1}{2}m\ddot{x} + kx\dot{x}
but the solution is suppose to be
\frac{d\mathcal{E}}{dt} = \dot{x}(m\ddot{x} + kx).
How?
The derivative is
How?
Hi dwsmith! :)
The first part of your energy is the kinetic energy.
However, kinetic energy contains speed squared instead of just speed.
So your energy formula should be:
$\qquad \mathcal{E} = \frac{1}{2}m\dot{x}^2 + \frac{1}{2}kx^2$
I like Serena said:
Hi dwsmith! :)
The book has a typo then.
