Differentiation and dot product
In summary, the question is asking to simplify the expression involving a dot product and cross product of a vector u. The conversation discusses the properties of the dot product and the use of the product rule to simplify the expression. The conversation ends with a suggestion to use the product rule in the given expression.
Benny
584
Can someone help me with the following question. I've been having trouble with problems of this kind for a while now.
Q. If the path u(t) (u is a vector) is differentiable at least three times, simplify:
[tex]
\frac{d}{{dt}}\left[ {\left( {u' \times u''} \right) \bullet \left( {u' - u} \right)} \right]
[/tex]
I can't remember the properties of the dot product but I know that the dot product is an inner product. So I will start by using the distributivity of the inner product.
[tex]\frac{d}{{dt}}\left[ {\left( {u' \times u''} \right) \bullet \left( {u' - u} \right)} \right][/tex]
[tex]
= \frac{d}{{dt}}\left[ {\left( {u' \times u''} \right) \bullet u' - \left( {u' \times u''} \right) \bullet u} \right]
[/tex]
It's not much but it's all I've got at the moment. The cross product will produce a single vector so there probably isn't much that I can do with it. Each of the two expressions inside the square bracket are scalars (scalar functions of t is probably the more accurate description) so I can probably continue as follows.
[tex]
= \frac{d}{{dt}}\left[ {\left( {u' \times u''} \right) \bullet u'} \right] - \frac{d}{{dt}}\left[ {\left( {u' \times u''} \right) \bullet u} \right]
[/tex]
Ok well I'm really stuck here. Does anyone have any suggestions? Thanks.
Why not just go ahead and do it?
I wouldn't even bother to distribute it like you did. Just use the product rule:
[tex]((u'Xu")\dot(u'- u))'= (u'Xu")'\dot(u'- u)+(u'Xu")\dot(u'- u)'[/tex]
[tex]= (u"Xu"+ u'X u"')\dot(u'- u)+ (u'Xu")\dot(u"- u')[/tex]
I can't see the Latex that you appear to have included in your reply. What I've got is the dot product of a cross product and the difference of two vectors. I don't see how the product rule can be used on the initial expression. Can you please explain further?
Edit: On second thought. The expression might just be the normal product(like 3 * 5 = 15). In that case I'd be able to this question. However I'd like to know if there is anything that can be done if the product is in fact a dot product rather than just the normal multiplication.
The usual "product rule" applies to dot product and cross product of vectors also: (u.v)'= u'.v+ u.v', (uxv)'= u'xv+ uxv'.
Sorry the Latex didn't work. I'm not sure what's wrong.
Ok thanks a lot for the help HallsofIvy.
FAQ: Differentiation and dot product
What is differentiation?
Differentiation is the process of finding the rate of change of a function with respect to one of its variables. It involves calculating the slope of a curve at any given point.
How is differentiation used in calculus?
Differentiation is a fundamental concept in calculus and is used to solve a variety of problems, such as finding maximum and minimum values of a function, determining rates of change, and analyzing the behavior of functions.
What is the dot product?
The dot product, also known as the scalar product, is an operation that takes two vectors and returns a scalar quantity. It is calculated by multiplying the corresponding components of the two vectors and adding them together.
How is the dot product used in vector calculus?
The dot product is used in vector calculus to find the angle between two vectors, determine whether two vectors are orthogonal (perpendicular), and to project one vector onto another.
Can the dot product be used with vectors in different dimensions?
Yes, the dot product can be used with vectors in any dimension as long as the two vectors have the same number of components. The resulting scalar value is the sum of the products of the corresponding components.
