Differentiation of a Taylor series
The discussion revolves around finding the Taylor series for the function g(x) = (1/4 + x)^(-5/2) by differentiating the Taylor series of f(x) = (1/4 + x)^(-3/2). The initial differentiation attempt yielded incorrect coefficients, leading to confusion about the correct factor and series. Participants clarified that the derivative of f(x) is not equal to g(x) and emphasized the importance of correctly applying the chain rule for differentiation. Ultimately, the participants suggested differentiating both sides of the initial expression to isolate the desired function, leading to the correct Taylor series for g(x).
cosmictide
Hi guys, any help on this question would be hugely appreciated.
The Taylor series about 0 for the function f(x)=(1/4+x)-3/2 is
f(x)=8 - 48x + 240x^2 - 1120x^3 + ...
used differentiation to find the Taylor series about 0 for the function g(x)=(1/4+x)-5/2
I tired differentiating each term to obtain 0-48+480x-3360x^2 but that can't be right since the correct answer seems to be g(x)=(1/4+x)^-5/2 to be 32-320x+2240x^2...
I'd be greatful if someone could shed some light on how I go about approaching this.
Thanks in advance. :smile:
Is the derivative of (1/4 + x)-3/2 equal to (1/4 + x)-5/2?
I also suggest using etc or LaTeX for readability.
Thanks for your reply. :smile:
The derivative of (1/4 + x)-3/2 is -48/(4x+1)5/2 so no they're not equal. I have no idea how to put that right though! Any help would be hugely appreciated.
Where did the 48 come from? It is correct that it should be a factor, but not 48 ...
Once you get the factor right and have done the differentiation of the Taylor series, you will have a factor times the expression you want on one side and a Taylor series on the other. How would you then solve for the expression you want?
Okay this time using the chain rule I calculated the derivative to be 3 / 2(1/4+x)5/2...is that any better?
I think once I get the factor right I just use it on the left-hand side to make the equation equal but not sure what it is yet. :cry:
Almost correct. The overall sign is not correct.
Yes, set this equal to the derivative of the expansion given at the beginning and then isolate (1/4+x)^{-5/2}
Thanks for the reply. :smile:
So I'm left with:
-3 / 2(1/4+x)5/2= -48x + 240x2 - 1120x3...
How do I isolate it? I've tried multiplying and dividing both sides by 3 and 2 but that's clearly wrong! Any help here would be greatly appreciated.
So I'm left with:
You obtained the left side by differentiating the left side of the initial expression, right? So you must also differentiate the right side. You have not done that yet. Do this and then isolate(1/4+x)^{-5/2}. That will work.
And you are welcome :-)
Likes 1 person
Thank you so much. :smile:
Good work!
You are very welcome.
You wrote\f(x) = \left(\frac{1}{4}+x\right) - \frac{3}{2}
Is that what you meant, or did you want
f(x) = \left(\frac{1}{4}+x\right) ^{-3/2} \, ?
If so, use parentheses, like this: f(x) = (1/4+ x)^(-3/2), or better still, ((1/4)+x)^(-3/2) or maybe [(1/4)+x]^(-3/2).
Anyway, assuming you want the second form above, we have
f'(x) = -\frac{3}{2} \left(\frac{1}{4}+x\right)^{-5/2} \neq \left(\frac{1}{4}+x\right)^{-5/2}
  • · Replies 27 ·
14K
