Differentiation with respect to a complex expression
In summary, the conversation discusses using substitution to solve an equation and provides step-by-step calculations and corrections to find the answer of -12/5.
Karol
1,380
$$(x-a)(x+a)=x^2-a^2$$
I have to express ##~\displaystyle x^2+16=f\left( \frac{x}{x-1} \right)##
I guess it has to be ##~\displaystyle \left( \frac{x}{x-1} \right)^n-a~## or ##~\displaystyle \left( \frac{x}{x-1} \pm a \right)^n##
I tried ##~\displaystyle \left( \frac{x}{x-1}+4 \right)^2~## but no good
Use substitution. Write ##y=\sqrt{x^2+16}## and ##t=x/(x-1)##. Then by the chain rule:
$$\frac{dy}{dt}=\frac{dy}{dx}\frac{dx}{dt}$$
and both factors on the RHS are easily calculated (the second by expressing ##x## in terms of ##t##).
$$\frac{dy}{dx}=\frac{1}{2}(x^2+16)^{-1/2}\cdot 2x=\frac{x}{\sqrt{x^2+16}}$$
$$x=\frac{t}{t-1},~\frac{dx}{dt}=\frac{-1}{t-1}$$
$$\frac{dy}{dt}=\frac{x}{\sqrt{x^2+16}}\frac{-1}{t-1}=\frac{x}{\sqrt{x^2+16}}(1-x)$$
$$x=3~\rightarrow~\frac{dy}{dt}=\frac{3(-2)}{5}=-\frac{6}{5}$$
The answer should be ##~\displaystyle -\frac{12}{5}##
Correction:
$$x=\frac{t}{t-1},~~\frac{dx}{dt}=\frac{-1}{(t-1)^2}=-(x-1)^2$$
$$\frac{dy}{dt}=\frac{-x(x-1)^2}{\sqrt{x^2+16}}$$
$$x=3~\rightarrow~\frac{dy}{dt}=-\frac{12}{5}$$
FAQ: Differentiation with respect to a complex expression
What is differentiation with respect to a complex expression?
Differentiation with respect to a complex expression is the process of finding the rate at which the output of a complex function changes with respect to a change in the input variable. It is similar to traditional differentiation, but with complex numbers instead of real numbers.
Why is differentiation with respect to a complex expression important?
Differentiation with respect to a complex expression is important in many areas of mathematics and science, including physics, engineering, and economics. It allows us to understand how complex systems behave and make predictions about their future behavior.
How is differentiation with respect to a complex expression different from traditional differentiation?
The main difference between differentiation with respect to a complex expression and traditional differentiation is that in complex differentiation, we must consider both the real and imaginary parts of the complex function. This involves using the rules of differentiation for complex numbers, such as the product rule and the chain rule.
What are some applications of differentiation with respect to a complex expression?
Some common applications of differentiation with respect to a complex expression include analyzing the behavior of electrical circuits, studying the motion of fluids, and predicting the behavior of financial markets. It is also used in many other areas of physics, engineering, and mathematics.
Can differentiation with respect to a complex expression be applied to any function?
Yes, differentiation with respect to a complex expression can be applied to any function that involves complex numbers. However, the function must be differentiable, meaning that it must have a well-defined derivative at every point in its domain.
