Difficult Planetary motion problem
In summary, Planet X rotates like Earth and is perfectly spherical. An astronaut weighing 950.0 N on Earth would weigh 917.0 N at its north pole and 860.0 N at its equator. The distance from the north pole to the equator is 1.883×104 km. The day on Planet X is about 9.82e7 seconds.
Hockeystar
64
Planet X rotates in the same manner as the earth, around an axis through its north and south poles, and is perfectly spherical. An astronaut who weighs 950.0 N on the Earth weighs 917.0 N at the north pole of Planet X and only 860.0 N at its equator. The distance from the north pole to the equator is 1.883×104 km , measured along the surface of Planet X. How long is the day on Planet X?
A lot
First we solve the radius of Planet:
circumfrence = 0.5pi(r)
r=11987550m
Next we solve m: 950N/9.8 m/s2 = 96.9kg
Then the tricky tricky part. Should I assume the loss of weight is equal to the centripetal force? In that case I have
mgnorth pole - mgequator = m4pi2r2/T2
T= 9.82e7s
However my answer is incorrect. Is my theory sound? Did I make a calculation error?
It all looks good except I think you have an extra r in m4pi²r²/T², which makes a large difference in the answer.
Look at your units. The left hand side has units of mass*acceleration or mass*length/time2. The units on the right hand side are mass*length2/time2. Once you get into the habit of checking units, it takes but a few seconds to double check that you have consistent units. When you don't have consistent units, as is the case here, you *know* you have made an error somewhere.
Thanks for the help guys :-)
Possible response:
Hello, thank you for presenting your solution attempt for this difficult planetary motion problem. Your approach of solving for the radius of Planet X and the mass of the astronaut is correct. However, your calculation for the day length may not be accurate due to a few potential factors.
Firstly, the loss of weight at the equator may not necessarily be equal to the centripetal force. It could also be affected by the planet's rotation rate and its gravitational field. Therefore, it would be best to approach this problem using the concept of rotational dynamics and conservation of angular momentum.
Secondly, the distance from the north pole to the equator is given in kilometers, but your calculations use meters. This could lead to a significant difference in the final answer.
Lastly, it is important to consider any other variables that may affect the day length on Planet X, such as the planet's mass and density. It would be helpful to double-check your calculations and also consider these additional factors in order to arrive at a more accurate answer. Keep up the good work!
Related to Difficult Planetary motion problem
1. What is a Difficult Planetary Motion Problem?
A Difficult Planetary Motion Problem is a problem that involves predicting and understanding the complex movements and interactions of planets and other celestial bodies in space.
2. Why is solving Difficult Planetary Motion Problems important?
Solving Difficult Planetary Motion Problems allows scientists to accurately predict the movements of planets and other celestial bodies, which is crucial for space exploration and understanding the universe.
3. What are some common challenges when solving Difficult Planetary Motion Problems?
Some common challenges when solving Difficult Planetary Motion Problems include accounting for the gravitational pull of multiple celestial bodies, dealing with non-uniform motion, and considering the effects of external forces such as solar winds.
4. How do scientists approach solving Difficult Planetary Motion Problems?
Scientists use mathematical models and equations, such as Newton's laws of motion and Kepler's laws of planetary motion, to analyze and predict the movements of planets and other celestial bodies. They also use advanced computer simulations and data analysis techniques.
5. What are some practical applications of solving Difficult Planetary Motion Problems?
Solving Difficult Planetary Motion Problems has practical applications in space exploration, satellite and spacecraft navigation, and predicting astronomical events like eclipses and planetary alignments. It also helps us understand the formation and evolution of our solar system and other planetary systems.
