Difficult Understanding Magnitude and Phase Shift of Transfer Function
The discussion centers on understanding the magnitude and phase shift of a transfer function. The original poster struggles with transitioning from the transfer function to the equations for magnitude and phase shift, questioning the logic behind finding the magnitude of the complex denominator. Clarifications suggest that multiplying the numerator and denominator by the complex conjugate can aid in understanding both the magnitude and phase angle. Additionally, graphical representation of complex numbers is recommended for better comprehension. Overall, the conversation emphasizes the importance of manipulating complex numbers to clarify these concepts.
wellmoisturizedfrog
TL;DR Summary
I am unsure if my current understanding of transfer functions is correct.
Hello,
My textbook offers the following transfer function as an example.
It then goes on to explain that the following equations represent the magnitude and phase shift of the transfer function.
However, I am having some difficulty jumping from the first equation to these equations. From my understanding, in order to find the magnitude of the transfer function, the magnitude of the complex number in the denominator is found. I'm not sure if this logic is correct.
I am also unsure about how the equation for the phase shift of the transfer equation has a negative sign in front. I understand the other aspects of it, though.
I would appreciate any clarifications.
Plotting the complex numbers graphically may help you understand why the denomiator is that way.
Multiply numerator and denominator by complex conjugate of denominator should help understand the angle.
And the magnitude as well......this is the standard way to manipulate complex numbers.
Likes scottdave and alan123hk
Ah I see, thank you for the insight! I appreciate the insight and resources.
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
