Diffraction by single slit - effect of increasing the slit width
In summary, increasing the slit width will decrease the width of the central maximum in the diffraction pattern, while increasing the wavelength will increase the width of the central maximum. These effects can be explained by the relationship between the distance from the central maximum and the wavelength and slit width.
physicsilliterate
For diffraction by a single slit, what is the effect of increasing (a) the slit width, and (b) the wavelength? It was a problem on my daughter's final and I never seemed to be able to answer it for her. :confused:
The answer lies in the fact that the minima are located at intervals of [itex]n\lambda / D[/itex] (value of sin)... so a bigger slit (D) makes narower maxima and a larger wavelenght ([itex]\lambda[/itex]) makes wider maxima.
for single-slit diffraction, the condition for MINIMUMs is:
[tex] y \ = \ \frac{m \lambda D}{s} [/tex]
where y is the distance from central max to the m-th minimum of the diffraction pattern, m a positive integer, λ the wavelength, D the distance between single-slit and distant observation screen where diffraction pattern will be observed, and s the single-slit width. Thus:
a) increasing single-slit width will decrease width of central max ("shrink the diffraction pattern");
b) increasing wavelength will increase width of central max ("expand the diffraction pattern")
FAQ: Diffraction by single slit - effect of increasing the slit width
What is diffraction by a single slit?
Diffraction by a single slit is a phenomenon where a beam of light passing through a narrow slit spreads out and produces a diffraction pattern on a screen placed behind the slit. This occurs due to the wave nature of light.
How does increasing the slit width affect diffraction?
Increasing the slit width decreases the amount of diffraction observed. This is because a wider slit allows more light to pass through without being diffracted, resulting in a narrower and less intense diffraction pattern.
What is the relationship between slit width and the spacing of the diffraction pattern?
The spacing of the diffraction pattern is directly proportional to the slit width. This means that as the slit width increases, the spacing between the bright fringes in the diffraction pattern also increases.
Why does the diffraction pattern become less distinct as the slit width increases?
As the slit width increases, the diffraction pattern becomes less distinct because the diffraction angles become smaller. This causes the diffracted light to spread out over a wider area, making it more difficult to distinguish individual fringes in the pattern.
Can diffraction by a single slit be observed with other types of waves?
Yes, diffraction can be observed with other types of waves such as sound waves and water waves. The principles of diffraction apply to all types of waves, where a narrow opening or obstacle causes the wave to spread out and produce a diffraction pattern.
