bfrank
- 3
A diffraction grating has 4,200 rulings/cm. On a screen 2.00 m from the grating, it is found that for a particular order m, the maximum corresponding to two closely spaced wavelengths of sodium (589.0 nm and 589.6 nm) are separated by 1.54 mm. Determine the value of m.
dsinθ = mλ (for bright fringes)
I spent about 15 minutes working this problem out under the assumption that sinθ ≈ tanθ = y/L. First, I drew a diagram of the corresponding bright fringes, and I made λ1 correspond to the wavelength that is higher on the screen, while λ2 is lower on the screen. Since λ1 has a larger angle in my diagram, I knew that λ1 should be 589.6 nm for my equations and λ2 should be 589.0 nm. Also, I knew that y2 = y1 - 1.54*10-3. I came up with two equations:
dsinθ1 = mλ1 → dy1/L = mλ1
dsinθ2 = mλ2 → dy2/L = mλ2 → d(y1 - 1.54*10-3) = mλ2
I divided these two equations, went through some algebra, solved for y1, and plugged it back into the first equation I found to solve for m; I got m = 3. However, I checked the back of the book and it says m = 2. So, I checked over my work again and realized that the small angle approximation I made does not hold because the angles are not small for diffraction gratings (correct me if I'm wrong). Now, I'm back to square one and honestly not sure where to go. I know sinθ = y/hypotenuse, but it seems like this route could get very algebraically sloppy, and I don't want to go down that road before getting some help.
Thank you!
