Diffraction Grating Vs Double-Slit: Small angle Approx.
In summary, when calculating the angle between the center bright fringe and the path length in double slit interference, the small angle approximation can be used because the distance between the slits is much smaller than the distance between the slits and the screen. However, this assumption does not hold for diffraction gratings because the spacing between the slits or lines is often on the same order as the wavelength. This leads to narrower intensity peaks in the resulting pattern, but the small angle approximation still applies at small angles for both double slit and multi-slit or multi-line gratings.
Beth N
41
In double slit interference , the angle between the center bright fringe and the path length (aka the angle used to find the path length difference) can be approximate as a small angle. However, we cannot assume the angles of bright fringes due to diffraction gratings are small. Why? What is the difference? What angles are they exactly?
##L= tan {\theta_m}##
##dsin {\theta_m}=m\lamda##
I think in double slit interference, the angle can be approximated as small because we assume the distance between the 2 slits are very small compared to the distance between the slits and the screen opposite from them. Can't see why diffraction grating is different?
A hint is that it depends on the size ## d ## which is often many times the wavelength for the case of just two slits, but typically is on the order of a wavelength for the spacing of the slits or lines in a diffraction grating. That isn't always the case, but it seems to be the assumption that you need to make here. (Edit: See the 3rd paragraph below for additional comments on this). ## \\ ## An item of interest here is the intensity peaks from a multi-slit or multi-line grating are narrower in the resulting ## \Delta \theta ## than the intensity peaks from a two-slit pattern, where for a grating with many slits or lines the intensity peak can be very narrow in the angular spread ## \Delta \theta ##. You can see this in the figures above where for even 5 slits, the intensity peaks are narrower than for the two-slit case in the appearance on the screen. For the two slit case, each of the peaks is a wide blob. For the 5 slit case, the bright red region of each intensity peak is a narrower stripe. This is not why the small angle approximation can not be used for a grating though. ## \\ ## The question doesn't seem to be what I would call a very accurate question. In addition, the more important feature of the difference between the double-slit and multi-slit or multi-line grating result is the more narrow intensity peaks that result. The "small angle" approximation does still apply for both the double slit and multi-slit or multi-line grating at small angles, and starts to break down as ## \theta ## gets larger for both cases. For this reason, I think the question really misses the boat.
Related to Diffraction Grating Vs Double-Slit: Small angle Approx.
1. What is the difference between a diffraction grating and a double-slit?
A diffraction grating is a device with many parallel slits that diffracts light into a spectrum, while a double-slit is a device with two parallel slits that creates an interference pattern.
2. How does the small angle approximation affect diffraction grating and double-slit experiments?
The small angle approximation assumes that the angle of diffraction or interference is small, allowing for simpler calculations and more accurate results.
3. Can a diffraction grating be used to create an interference pattern?
Yes, a diffraction grating can also create an interference pattern if the light source is monochromatic and the slits are very close together.
4. Which device is better for studying the properties of light - a diffraction grating or a double-slit?
It depends on the specific properties of light being studied. Diffraction gratings are better for analyzing the spectral distribution of light, while double-slits are better for studying interference patterns.
5. Are there any practical applications for understanding the small angle approximation in diffraction and interference experiments?
Yes, the small angle approximation is used in various fields, such as optics, astronomy, and spectroscopy, to accurately measure and analyze light phenomena. It also allows for the design of more efficient and precise optical instruments.
