shyguy79
- 102
A laser with monochromatic light of frequency 6.33 × 10^14 Hz is fired through a diffraction grating.
If the first minimum in this diffraction pattern coincides with the position of the second order that was seen in the previous diffraction pattern, what is the width of the slit?
[itex]w=\frac{\gamma}{\sin\theta}[/itex]
[itex]n\gamma=d\sin\theta_{n}[/itex]
Here are my results from a previous question to which it refers
Using the following values: [itex]\gamma=633nm[/itex]
and [itex]\theta=39.3^{o}[/itex]
and the equation [itex]n\gamma=dsin\theta_{n}[/itex]
Rearranged for distance between the slits [itex]d=\frac{n\gamma}{sin\theta_{n}}[/itex]
then [itex]d=\tfrac{5*633x10^{-9}m}{sin(39.3)}=5\mu m[/itex] or 5.00E^{-6}m
Now to answer this question I've calculated the distance between the slits:
First calculate the distance between the slits second order using the equation [itex]d=\frac{n\gamma}{sin\theta} = \frac{2*633E^{-9}m}{sin(39.3)}=2\mu m[/itex] or 2.0E{}^{-6}
m.
This is where I don't know where to go... I know I need w... but how? Please help, I've had a thought:
by combining the two equations and substituting for [itex]\sin\theta[/itex] then maybe [itex]\frac{n\gamma}{d}=\frac{\gamma}{w}[/itex] so [itex]w=\frac{\gamma d}{n\gamma}=\frac{d}{n}[/itex]
