Diffraction theory, power density and angle of incidence
kagestodder
TL;DR Summary
My question: How do i account for the angle of incidence so that there is a connection between the amount of power hitting the aperture is the same that also gets diffracted.
Hello everybody
I am currently looking at diffraction through a rectangular aperture. I am looking at an aperture which is large compared to wavelength, and am looking at diffraction at all angles behind the aperture in a distance which is approx equal to the size of the aperture. I am computing diffraction patterns computationally.
I have now hit somewhat of a wall wrt. understanding of the diffraction integrals. I am using kirchhoff diffraction integral and rayleigh-sommerfeldt diffraction integral, where the only difference between them is how the obliquity factor is defined(?).
The issue arises when i look at the problem wrt. power. Do the diffraction integral account for the angle of incidence of the plane wave hitting the aperture? Say a plane wave at an incidencde hits the aperture with some power density. The angle of incidence will affect the visible area of the aperture, and therefore the amount of energy hitting the aperture. When looking at kirchhoffs diffraction integral the two cosines of the integral will say that even when the incident wave hits the aperture at a large angle to the normal of the aperture, there will still be quite a powerfull diffracted field. But from a power perspective, almost nothing will hit the aperture. And the rayleigh-sommerfeldt diffraction integral has no parameter for the angle of incidence. Would it make sense to look at the incoming power desnity, convert this to a E-field value using the apparent aperture area and then use this as U0?
I hope this makes sense. Please correct me as i feel i am on deep water with this at the moment! :)
Science news on Phys.org
I think the way to look at this from a practical point of view is that the problem is the same as for a narrow mirror instead of a slit. In such a case it seems that the power hitting the projected area of the mirror should be used, and the reflected beam will be concentrated at the geometrical angle of reflection. The diffraction effects, however, will broaden the beam and will create sidelobes. I notice that you are very close to the slit, within the near radiation zone no doubt, so the incident power will vary across the aperture and in addition, the diffracted pattern will vary with distance.
Reading the question more closely it seems slightly simpler than I had supposed. Although the emergent rays are measured close to the slit, so the pattern will vary with distance, the incident power is uniform across the slit. The incident power will still be that striking the projected area of the slit.
Thanks
This was my assumption as Well. However it does not seem to hold such that the power hitting the slit (or mirror if we look at it like that) is not equal to integrating the power over a half sphere on the diffracted side of the aperture. This is the reason why I have become unsure.
So to me it seems like there is less power diffracted than hitting the aperture.
I compare
Pin = E0*E0*A
And
Pr = sum(Er*Er*2pi*r*r/ds), with ds being the sampling area of each point in the half sphere. And A the area of the aperture.
The values should be comparable and close to each other.
I may still be looking at this the wrong way.
Are you using the square of field strength when you calculate power?
Yes abs E squared!
I have been unable to find any sources or anything looking at these diffraction scenarios with regards to power in / power out. Any cases with results that I could copy the geometry from to verify my calculations could also help. For now it seems like the power hitting the aperture is more than gets diffracted on the other side of the aperture.
FAQ: Diffraction theory, power density and angle of incidence
What is diffraction theory?
Diffraction theory is the study of how waves, such as light or sound, interact with obstacles or openings. It explains how waves bend, spread out, and interfere with each other when they encounter edges, slits, or apertures. This theory is essential for understanding various phenomena in optics, acoustics, and other fields where wave behavior is important.
How does power density relate to diffraction?
Power density, which is the amount of power per unit area, is influenced by diffraction because the spreading of waves can cause the power to be distributed over a larger area. When waves diffract, the energy is spread out, leading to variations in power density at different points. Understanding this relationship is crucial for applications like antenna design, where power density affects signal strength and coverage.
What is the angle of incidence in diffraction?
The angle of incidence refers to the angle at which an incoming wavefront strikes a surface or an obstacle. In the context of diffraction, the angle of incidence can affect the pattern and intensity of the diffracted waves. For example, light hitting a diffraction grating at different angles can produce varying diffraction patterns, which are used in spectroscopy to analyze the composition of materials.
How do you calculate the diffraction pattern of a wave?
The diffraction pattern of a wave can be calculated using principles from Huygens-Fresnel theory and Fourier optics. By treating each point on a wavefront as a source of secondary spherical wavelets, the resulting interference pattern can be determined. Mathematical tools like the Fourier transform are often used to analyze and predict the intensity distribution of the diffracted waves.
What are some practical applications of diffraction theory?
Diffraction theory has numerous practical applications across various fields. In optics, it is used to design lenses, microscopes, and telescopes. In telecommunications, it helps in the design of antennas and the analysis of signal propagation. Additionally, diffraction is essential in the study of crystallography to determine the atomic structure of materials, and in the development of optical instruments like diffraction gratings and spectrometers.
