Diffusion behavior of particulates
In summary, the diffusion of PM2.5 particulates is affected by the leakiness of a house and the dust on interior surfaces, with the rate of generation and removal being key factors. The use of an air purifier can help reduce the concentration of airborne particles, but the rate of rise may still be affected by air exchange and dust accumulation. The rate of PM2.5 rise can vary significantly depending on factors such as air leakage, dust accumulation, and frequency of dusting.
chirhone
300
25
How do the pm2.5 (particles of 2.5 microns or less) diffuse compared to gas. I noticed when i turned on my air purifier at night and turned it off at daytime. The pm2.5 particles levels go back to high after 2 hours even when my doors and windows are closed. Do pm2.5 particles pass through microscopic holes below doors like gas? How does the diffusion of particulates differ to that of gas?
How are you measuring your pm2.5 particulates?
Your doors and windows may be closed, but your house is always leaking air. Air leaks out, and for every cubic foot that leaks out, an equal cubic foot leaks in. Older house leak a lot, new houses in cold climates have to meet codes that require less leakage. Good search terms to start with are home air changes per hour or home air leakage.
Since air is leaking in, particulates floating in that air are coming with it. The rate of PM2.5 rise is a measure of the leakiness of your house.
Likes chirhone
I would think a more likely explanation for variations on the few hours scale would be the dust on the surfaces of the interior of your home. Even a clean home can have milligrams of dust per square meter. My house is probably closer to grams per square meter. A small fraction of this dust is constantly being kicked up by air currents and settling back down on surfaces. The surfaces act as a semi-infinite source of airborne particles produced at a semi-constant rate (proportional to the quantity of dust, but that will only change slowly through the process of filtering the air). The rate at which the dust settles is proportional to the concentration of airborne particles. The concentration in the air rises until the rate of settling out equals the rate of generation. When you add a filter the rate of removal is still proportional to the airborne concentration, but the proportionality is now much larger. The rate of generation equals the rate of removal at a much lower airborne concentration. When you turn the filter off the concentration quickly (and 2 hours is quickly) rises to the previous equilibrium.
Over a longer time the filter will reduce the total available dust, but your coming and going not to mention air exchange with the outside will also be increasing the amount of dust. How often you dust is another critical factor. So there is a longer term equilibrium being generated by exchange of dust with the outside world which is most of what was discussed above. However I think the two hour time scale you are describing is going to be about what is already inside the home.
Likes chirhone
Do you know how high can pm2.5 pollution get? I leased on a 32th floor. And when the windows are opened. I am getting 10 times the reading compared to when the windows are closed and air purifier running at maximum.
What is your comment about diffusion behavior of Pm2.5 particles. My leased condo at 32th floor has moderate amount of pm2.5 particles. This is because the condo building is at corner of busy intersection. I tested the unit at place 3.5 kilometers with less busy street or lack of street and the pm2.5 particles are very low. My question is why didnt the particles in the busy street diffuse to that of less busy or even lack of street. Its just 3.5 kilometers away. This is why i want to understand how pm2.5 particles diffuse.
Related to Diffusion behavior of particulates
What is diffusion behavior?
Diffusion behavior refers to the movement of particles from an area of high concentration to an area of low concentration. This process occurs naturally and is driven by the random motion of particles.
What factors affect the diffusion behavior of particulates?
The diffusion behavior of particulates can be affected by several factors, including temperature, concentration gradient, particle size, and the medium through which the particles are diffusing.
How is the rate of diffusion measured?
The rate of diffusion can be measured by observing the change in concentration over time. This can be done using techniques such as spectrophotometry or by tracking the movement of particles under a microscope.
What is the importance of understanding diffusion behavior?
Understanding diffusion behavior is important in many scientific fields, including chemistry, biology, and environmental science. It can help us understand how substances move and interact in various systems, and it has practical applications in industries such as pharmaceuticals and food production.
Can diffusion behavior be manipulated?
Yes, diffusion behavior can be manipulated through various methods such as changing the temperature, concentration, or size of the particles, as well as altering the properties of the medium. This can be useful in controlling the movement of substances in a desired direction or rate.
  • Biology and Medical
  • Mechanics
