Why Isn't My Cloud Chamber Showing Tracks?
In summary, the individual encountered two problems while working on their cloud chamber. One issue was the lack of tracks, which may be due to the absence of a radioactive source or interference from lighting. The other problem was the presence of a purplish liquid in the chamber, which they suspect may be a result of the difuroethane from the duster and isopropyl alcohol. They also shared images of their cloud chamber setup and sought advice from other users, including suggestions to use 99% propylene or dry ice instead of compressed air and to try experimenting with different lighting and a radioactive source.
Thundagere
159
I was working on my cloud chamber today, and I ran into two problems:
A) It's not working :) To be more specific, I used compressed air to get the bottom extremely cold. The structure itself is a small plastic throw away cup, with a sponge with 91% alcohol stuck to the top. The bottom (the open end of the cup) is covered in a thin metal plate, and I spray the air onto that. It gets really, really cold. However, I was unable to see any tracks. Is this because i don't havea radioactive source? I thought I might be able to see a muon or positron every now and then, but I guess not...
Also, once I was done, a purplish liquid was remaining in the cloud chamber. Could this be a product of the difuroethane from the duster and the isopropyl alcohol? I'm not sure about this.
The purple liquid. I got it into a tube as soon as it came, since I'm still not sure what it is.
http://imageshack.us/a/img525/7906/20121122131134.jpg
The set up of the cloud chamber. It looks nasty right now, but that's mostly because of the liquid. Metal bottom, sealed with plasticine. Sponge on top. Black background.
http://imageshack.us/a/img831/1209/20121122131226.jpg
Any help would be appreciated!
UPDATE: The liquid is definitely primarily alcohol based. I did some tests, and it's definitely flammable (don't have much left now, lol), and smells like alcohol. I'm just not sure what gives it the purple color.
Are you sure you have oversaturated alcohol (?) there?
A radioactive source would increase the number of tracks, but you should get tracks based on natural radioactivity without, too. Something like a few tracks per dm^3 and second.
I'm pretty sure. It's 91% which should work. I soaked the sponge throughly too.
may guess is that that the alcohol caused some reaction in the sponge or cup? Try using 99% propylene (you can get it cheap online)
Why wouldn't 91% work though? Or does it take time? I think I only waited about 10 minutes,since I have a limited supply of canned air.
I've used 91% isopropyl alcohol successfully in a similar cloud chamber, so that shouldn't be the problem. Since you don't mention this, my guess is that your lighting is interfering. You need to be in a very dark room (I also had some success outside at night). Then shine a flashlight into the chamber. Like you I taped a piece of black paper to the back side of the chamber, on the inside, for better contrast.
Play around with the angle of the flashlight. Even before you see any tracks, if it's working properly you should see a fine mist falling on the inside of your chamber. If you can see this mist you can probably also see any tracks that might show up. If you can't see this falling mist I don't think you'll see any tracks.
My cloud chamber had, at a guess, three times the volume of yours. Without any radioactive sources, I saw something like a track per minute on average (I assumed from cosmic rays, but maybe it was actually local background radioactivity? Which one dominates?).
Time might be an issue. It takes a little while (5 minutes?) for the air in the chamber to cool down, and the mist doesn't start falling until then. And you might only see a track every 5 minutes or something. I used dry ice instead of compressed air; it's cheap and you can get a nice big chunk of it that will last 24 hours.
If you pry the americium source out of a smoke detector and put it at the bottom of your chamber, it will shoot off tons of alpha particles, producing many tracks per second if things are working properly.
Try using Dry ice instead of canned air. It will work MUCH better.
I'll definitely try the night thing. I can see the mist falling for sure, so I guess I'm doing something right. I've switched to a smaller jar for now.
One thing, should I wait a while? If the sponge has alcohol, should I wait for it to evaporate, then start the freezing?
I've considered the americanum thing, but I need to find a spare smoke detector around here somewhere.
FYI, the purpose of this experiment was to see whether it could be done reliably with canned air, and see if there are any other factors that need to be taken into account :). I guess I should have mentioned that, but I would rather not use dry ice or peltier coolers, as that defeats the purpose of the experiment.
Thanks for the help!
Any ideas on what the purple liquid might be? I'm thinking it could be pure, 100% alcohol. At -40 odd degrees celsius, the water would have frozen, but not the alcohol. leaving that purplish residue. It's definitely alcohol based as it burns fine, and smells of alcohol.
You might get the setup working with dry ice and then switch to compressed air and see if it still works. Good experiments have control trials!
Related to Why Isn't My Cloud Chamber Showing Tracks?
1. What is a Diffusion Cloud Chamber?
A Diffusion Cloud Chamber is a scientific instrument used to detect and study the presence of subatomic particles such as electrons, protons, and alpha particles. It works by creating a supersaturated vapor of alcohol, which allows the particles to leave a trail of condensation as they pass through the chamber.
2. How does a Diffusion Cloud Chamber work?
A Diffusion Cloud Chamber works by creating a saturated vapor of alcohol and then expanding it into a larger volume. This causes the vapor to become supersaturated, meaning that it contains more alcohol molecules than it can normally hold. When a charged particle passes through the chamber, it ionizes the alcohol molecules and creates a trail of condensation, making the particle visible.
3. What are some common issues with Diffusion Cloud Chambers?
Some common issues with Diffusion Cloud Chambers include leakage of alcohol, contamination of the chamber, and difficulty in maintaining a stable supersaturation level. Other issues may include technical difficulties in building and operating the chamber, and potential hazards associated with handling alcohol and working with high voltages.
4. How can I troubleshoot issues with my Diffusion Cloud Chamber?
If you are experiencing issues with your Diffusion Cloud Chamber, there are a few steps you can take to troubleshoot the problem. First, check for any leaks or contamination in the chamber. Next, make sure the supersaturation level is stable and adjust the temperature and pressure as needed. If the problem persists, consult the manual or seek assistance from a more experienced user or manufacturer.
5. What are some applications of Diffusion Cloud Chambers?
Diffusion Cloud Chambers have various applications in particle physics and nuclear physics. They are commonly used to study cosmic rays, radioactive decay, and interactions between subatomic particles. They can also be used in education and outreach to demonstrate the presence and behavior of particles that are invisible to the naked eye.
  • Other Physics Topics
