Diffusion current in a circuit containing semiconductor but no electric source
In summary, diffusion current occurs in a circuit with an N-type or P-type semiconductor even without being connected to an electric source like a battery. This is a transient current that can only be measured at the time of making a p-n junction. When the circuit is connected to a battery, both drift and diffusion current can occur. For more information, please refer to the provided link.
Eng.
Please I need help to understand how diffusion current can occur in a circuit that contains an N-type or P-type semiconductor without being connected to an electric souce such as a battery.And how can both drift and diffusion current occur when the circuit is connected to a battery?
Diffusion current will be a transient at the time of making of a p-n junction. You won't be able to measure it then.
FAQ: Diffusion current in a circuit containing semiconductor but no electric source
1. What is diffusion current in a circuit containing a semiconductor but no electric source?
Diffusion current is a type of current that occurs in a semiconductor when there is a concentration gradient of charge carriers. This means that there are more charge carriers in one area of the semiconductor than another, causing them to diffuse or move from an area of high concentration to an area of low concentration.
2. How does diffusion current affect the behavior of a circuit?
In a circuit containing a semiconductor but no electric source, diffusion current can still flow and contribute to the overall behavior of the circuit. This current can affect the voltage and current in the circuit, as well as the resistance and capacitance.
3. What is the difference between diffusion current and drift current?
Diffusion current and drift current are two types of current that can occur in a semiconductor. Diffusion current is caused by a concentration gradient of charge carriers, while drift current is caused by an electric field. Additionally, diffusion current is typically larger and tends to flow in the opposite direction of drift current.
4. How does the concentration gradient of charge carriers affect diffusion current?
The magnitude of diffusion current is directly proportional to the concentration gradient of charge carriers in a semiconductor. This means that a larger concentration gradient will result in a larger diffusion current, while a smaller gradient will result in a smaller diffusion current.
5. Can diffusion current be controlled or manipulated in a circuit?
Yes, diffusion current can be controlled and manipulated in a circuit by adjusting the concentration gradient of charge carriers in the semiconductor. This can be achieved through processes such as doping or by applying an external electric field.
