Difution drift currect question
  • Thread starter nhrock3
  • Tags
    Drift
In summary, the equation J_e=q\mu \bar{n}E-qD_e\frac{d\bar{n}}{dx} represents the diffusion drift current, where \mu is the drift coefficient and E is the field. The rest of the members represent the electron density, derivative of electron density with respect to the coordinate x, and diffusion coefficient of electrons. The formula for hole current has a plus in the middle because holes are positively charged, while in the electron current there is a minus in the middle because electrons are negatively charged. Additionally, the diffusion coefficient for holes is denoted as D_p.
nhrock3
415
[tex]J_e=q\mu \bar{n}E-qD_e\frac{d\bar{n}}{dx}[/tex]
i can't understand this equation
what each member of this equation
i only know that [tex]\mu[/tex] is the drift coefficient
E is the field
what the rest of the memebers represent
E is the field
I googled diffusion drift current, and got lots of good hits. Here's one that should answer your question:
http://ecee.colorado.edu/~bart/book/book/chapter2/ch2_10.htm
n is the electron density what is the meening of
dn/dx
in this page it doesn't say what is D_e
the is also a formula for hole current
why it has plus in the middle (in the electron current we have minus in the meedle)
dn/dx
dn/dx would be the derivative of electron density with respect to the coordinate x. In other words, if you're simply dealing with a semiconductor in which the elctron density only changes in x (i.e. y, and z components are constant), there will be a diffusion current where electrons will diffuse from a higher concentration area to a lower concentration area. This is mathematically depicted by 'dn/dx'.
D_e (or D_n) is the diffusion coefficient of electrons. It depends on the mobility of the electrons, and temperature of the sample.
The hole current has a plus because holes are positively charged as opposed to electrons which are negatively charged
Related to Difution drift currect question
1. What is diffusion drift current?
Diffusion drift current is a type of electrical current that is caused by the diffusion of electrons and holes in a semiconductor material. It is a combination of diffusion current, which is caused by the natural movement of charge carriers from areas of high concentration to low concentration, and drift current, which is caused by an applied electric field.
2. How does diffusion drift current affect electronic devices?
Diffusion drift current can affect electronic devices in two ways. First, it can cause unwanted leakage currents in devices, which can lead to reduced performance or failure. Second, it can be harnessed in certain devices, such as transistors, to control the flow of current and create useful functions.
3. What factors affect the magnitude of diffusion drift current?
The magnitude of diffusion drift current is affected by several factors. These include the concentration of charge carriers in the material, the temperature of the material, and the strength of the applied electric field. Additionally, the physical properties of the material, such as its bandgap and carrier mobility, can also impact the diffusion drift current.
4. How is diffusion drift current measured?
Diffusion drift current can be measured using various techniques, such as Hall effect measurements or current-voltage (IV) measurements. In Hall effect measurements, an external magnetic field is applied to the material, and the resulting voltage can be used to calculate the diffusion drift current. In IV measurements, the current is measured at different voltages to determine the current-voltage relationship and infer the diffusion drift current.
5. What are some practical applications of diffusion drift current?
Diffusion drift current has various practical applications in electronic devices. For example, it is used in transistors to control the flow of current and amplify signals. It is also utilized in diodes to convert AC signals to DC signals. Additionally, diffusion drift current plays a crucial role in the operation of solar cells, as it is responsible for the conversion of light energy into electrical energy.
