MHB Digit word problems -linear equation
  • Thread starter Thread starter paulmdrdo1
The discussion centers on solving a problem involving two consecutive positive odd integers where the difference of their squares equals 64. The first solution incorrectly calculates the value of x, yielding integers 19 and 21 instead of the correct pair. The second solution correctly identifies the integers as 15 and 17, with x equating to 15. The confusion arises from the miscalculation in the first method, where x should have been 7 instead of 9. Ultimately, the second method provides the accurate answer to the problem.
paulmdrdo1
can you please tell why my solutions here yield different answers
here's the problem,
Find two consecutive positive odd integers such that the difference of their squares is 64.
my first solution is
let $2x+1=$ smaller odd interger
$2x+3=$ larger odd integer
$(2x+3)^2-(2x+1)^2=64$
$x=9$
the numbers are 19 and 21.
my 2nd solution
let $x=$ smaller odd interger
$x+2=$ larger odd integer
$(x+2)^2-(x)^2=64$
$x=15$
the numbers are 15 and 17.
which solution method is correct?
thanks!
Mathematics news on Phys.org
$x=9$
This should be $x=7$.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
