Dilation generator in QM; Problem 3.1 in Ballentine
In summary, the conversation discusses problem 3.1 from Ballentine's Quantum Mechanics textbook, which involves determining the commutator between the generators of dilation and space displacements. Two methods are discussed, one involving finding the generator and the other involving using the group properties directly. It is noted that for symmetries, the coordinate representation is secondary and the group properties are primary. The value of the numerical factor for dilations depends on the dimensionality of the space.
GreyZephyr
I am working my way through Ballentine's Quantum Mechanics and I am stuck on the following problem.
Problem 3.1 from Ballentine: Quantum Mechanics
Space is invariant under the scale transformation [tex]x\to x'=e^cx[/tex]
where [tex]c[/tex] is a parameter. The corresponding unitary operator may be written as [tex]e^{-icD}[/tex] where [tex]D[/tex] is the dilation generator. Determine the commutator [tex]\left[D,\mathbf{P}\right][/tex] between the generators of dilation and space displacements.
By looking at [tex]e^{i\epsilon D}e^{-i\epsilon P}e^{-i\epsilon D}e^{i\epsilon P}=I+\epsilon^2[P,D][/tex] and comparing this with the transformations the LHS represents, i.e
[tex]
\begin{align*}
(x_1,x_2,x_3,t)&\to(x_1+\epsilon,x_2,x_3,t)\\
&\to(e^{-\epsilon}(x_1+\epsilon),e^{-\epsilon}x_2,e^{-\epsilon}x_3,t)\\
&\dots\\
&\to(x_1+\epsilon-\epsilon e^{-\epsilon},x_2,x_3,t)\\
&\to(x_1+\epsilon^2,x_2,x_3,t)
\end{align*}
[/tex]
I get [tex][D,P_\alpha]=iP_\alpha +?I[/tex] and I can then do the same thing with the angular momentum and use Jacobi identity to determine that the scale factor in front of [tex]I[/tex] is 0. However this seems very clumsy. To me it looks like the problem is just asking about the generators of the lie group. However I get confused as to what the group should be. Is it is still just the Galilei group? If this is the case, is there not some way to immediately get the answer from the commutation relations of the generators of the Galilei group without resorting to infinitesimal generators?
Given my confusion, I was wondering if anyone could explain, or recommend a book, that details how to find the generators in a more rigours fashion than Ballentine, that is, explains the relationship between the group structure and the physics. I like the clarity of the ideas, in his book, but am finding myself confused over some of the details of implementing them.
Whenever you have space transformation L, it also acts on functions (in QM - state vectors) by U(L) according to the formula.
[tex](U(L)f)(x)=f(L^{-1}x)[/tex]
This is not a very good formula, because U(L) so defined will not be unitary. Yet here comes the fact that state vectors are defined up to a proportionality factor, so we can put a numerical factor in front.Thus we will have[tex](U(L)f)(x)= a(L) f(L^{-1}x)[/tex]
What numerical factor should we put for dilations?
For a dilation [itex]x\mapsto \lambda x[/itex] we want [itex]U(\lambda)[/itex] to preserve the norm. So we should have
[tex]|a(\lambda)|^2\int |f(\lambda^{-1}x)|^2 d^3x=\int |f(x)|^2 d^3x[/tex]
We change the variables: [itex]y=\lambda^{-1}x,\, x=\lambda y[/itex] thus
[tex]d^3x=\lambda^3 d^3y[/tex]
and we find that mu st have
[tex]|a(\lambda)|^2\lambda^3=1[/tex]
with an evident solution
[tex]a(\lambda)=\lambda^{-3/2}[/tex]
So we have our unitary operator
[tex](U(\lambda)f)(x)=\lambda^{-3/2}f(\lambda^{-1}x)[/tex]
Put here [itex]\lambda=e^c[/itex]
and you get
[tex](U(c)f)(x)=exp(-3c/2)f(e^{-c}x)[/tex]
Now you can do Taylor expansion around [itex]c=0[/itex] to find the generator D. Once you have the generator, you can calculate its commutator with P. Of course you can also calculate the commutator without finding the generator by checking what will be the action of [itex]U(c)T(a)U(c)^{-1}[/itex] on wave functions, where [itex]T(a)[/itex] is the translation. That is easy. Then you expand in c and in a. The numerical factor discussed above will then cancel out - it is irrelevant for just getting the commutator.
P.S. What I wrote above needs to be verified. I was writing directly out of my head, without checking. And all [itex]x[/itex] above should be bold [itex]\mathbf{x}[/itex]
Thank you for the reply. It helped a lot though, I have a further question after expanding around $c$ i obtain a generator of the form [tex]-\frac{1}{2} -\mathbf{x}\cdot D[/tex] where [tex]D[/tex] is the differential operator. This then gives the commutator [tex][U,P]=\mathbf{x}.DP+P\mathbf{x}D[/tex].
and if we then choose to express [tex]P=iD[/tex] we obtain [tex][U,p]=-iP[/tex], which almost agrees with the answer I get from expanding out [tex]UPU^{-1}[/tex]. But what I don't understand, is where in the second method i have assumed the coordinate representation of [tex]P[/tex]. Also, other than the fact that [tex]UTU^{-1}[/tex] corresponds to the change of basis for the transformation, and hence leads to a diagonalizable matrix representation, is there any particular reason to choose it for calculateing the commutator, for it seems I could also get the answer from expressions such as [tex]UTU^{-1}T^{-1}[/tex].
Finally sorry for the delay in my reply, but I did not have Internet access for a day.
For symmetries coordinate representation is secondary, group properties are primary. Take for instance trnslations. They act by [itex]x\mapsto x+a[/itex]. Therefore they should act on functions via
[tex](U(a)f)(x)=f(x-a)[/itex]
No numerical factor is needed in this case - this is a unitary transformation because Lebesgue measure is invariant under translations. If [itex]\hat{x}[/tex] is the position operator
[tex](\hat{x}f)(x)=xf(x)[/tex]
you can calculate from these definitions [itex]U(a)\hat{x}U(a)^{-1}[/itex], expand around a=0, and get the commutation between positions and momenta (generators of U(a)) without calculating the representation of the momentum operator as a differential operator.
P.S. In the previous note I assumed that we are in 3 dimensions. The value of the numerical factor for dilations depends on the dimensionality of the space. I should have made it clear.
Thank you for your help. That [tex]\mathbf{x}\in\mathbb{R}^3[/tex] was clear from the integral.
FAQ: Dilation generator in QM; Problem 3.1 in Ballentine
What is the Dilation generator in Quantum Mechanics?
The Dilation generator, also known as the Hamiltonian operator, is a mathematical representation of the total energy of a quantum system. It is a Hermitian operator that acts on the wave function of a quantum particle and determines its evolution over time.
How is the Dilation generator related to Problem 3.1 in Ballentine?
Problem 3.1 in Ballentine's book "Quantum Mechanics: A Modern Development" discusses the time evolution of a quantum system using the Schrödinger equation. The Dilation generator is a key component in this equation, as it represents the total energy of the system and determines its evolution over time.
What is the significance of the Dilation generator in Quantum Mechanics?
The Dilation generator is crucial in understanding the behavior of quantum systems. It allows us to calculate the time evolution of a system and predict its future state. It also plays a role in many other important concepts in Quantum Mechanics, such as wave functions, energy eigenstates, and quantum superposition.
How is the Dilation generator defined and represented mathematically?
The Dilation generator is defined as a Hermitian operator, denoted as H, that acts on the wave function of a quantum particle. Mathematically, it is represented as a matrix with entries that correspond to the potential and kinetic energy of the system. In some cases, it can also be represented as a differential operator in the Schrödinger equation.
Can the Dilation generator be used in all quantum systems?
Yes, the Dilation generator can be used in all quantum systems, regardless of their complexity. It is a fundamental concept in Quantum Mechanics and is applicable to all physical systems, from simple particles to complex molecules and even the entire universe. However, the specific form and representation of the Dilation generator may vary depending on the system under study.
