Fortran Dimension of arrays (RESHAPE) in Fortran 90
The discussion revolves around a Fortran program named "testmatek" that attempts to create and manipulate a complex matrix. The code initializes parameters and attempts to populate a 2x2 matrix using the RESHAPE function. However, an error occurs due to a syntax issue at line 20, where the program expects an identifier but encounters a closing parenthesis instead. Participants discuss the purpose of the RESHAPE function, clarifying that it is intended to convert Fortran arrays to C-compatible formats. A user expresses frustration over their lack of understanding of Fortran and seeks assistance in resolving the syntax error. The conversation highlights the challenges faced by beginners in Fortran programming and the importance of understanding array manipulation functions.
MahdiI84
TL;DR Summary
Hello everyone. I am new to Fortran. The following coding is for a 2x2 matrix whose original diameter is zero and its non-original diameter requires writing a loop. The code I wrote now has an error that I am unable to fix. Please help me solve it. Thanks
Fortran:
program testmatek
implicit none
integer :: Nc=1000 ,k
integer,parameter :: N=2
REAL :: kx ,a0=1.0 ,t0=0.25
DOUBLE PRECISION :: pi=4*ATAN(1.)
COMPLEX , PARAMETER :: i=(0,1)
complex :: ek1 ,ek2
complex ::  MATRIX_ek(N,N)
 open(1,file='matek.txt')
    MATRIX_ek(N,N)=(0,0)
 DO k=-Nc,+Nc
    kx=(pi*k)/(1000*a0)
    ek1=t0*(1+EXP(-2*i*kx*a0))
    ek2=t0*(1+EXP(2*i*kx*a0))
    MATRIX_ek=RESHAPE((/0.0,eK2,ek1,0.0/ ) , (/2,2/))
    write(1,*) MATRIX_ek
 end do
 end program testmatek
1>C:\Users\mahdi\Documents\Visual Studio 2012\Projects\Console4\Console4\Source1.f90(21): error #5082: Syntax error, found ')' when expecting one of: ( <IDENTIFIER> <CHAR_CON_KIND_PARAM> <CHAR_NAM_KIND_PARAM> <CHARACTER_CONSTANT> <INTEGER_CONSTANT> ...
Technology news on Phys.org
The error appears at line 20. Have you searched online for examples of using the RESHAPE function?
Why in heaven's name are you using RESHAPE?
RESHAPE is there to convert FORTRAN-type arrays to C-type arrays, so you can pass them to C functions.
Yes, I know where the error is. Of course, I searched the internet. But since I am new to Fortran, I did not understand how I could fix the error. Thank you for your help
Thread 'Star maps using Blender'
Blender just recently dropped a new version, 4.5(with 5.0 on the horizon), and within it was a new feature for which I immediately thought of a use for. The new feature was a .csv importer for Geometry nodes. Geometry nodes are a method of modelling that uses a node tree to create 3D models which offers more flexibility than straight modeling does. The .csv importer node allows you to bring in a .csv file and use the data in it to control aspects of your model. So for example, if you...
I tried a web search "the loss of programming ", and found an article saying that all aspects of writing, developing, and testing software programs will one day all be handled through artificial intelligence. One must wonder then, who is responsible. WHO is responsible for any problems, bugs, deficiencies, or whatever malfunctions which the programs make their users endure? Things may work wrong however the "wrong" happens. AI needs to fix the problems for the users. Any way to...
9K
