Dimensional Analysis and constant
In summary, Homework Equations state that V-A=B/t+Ct^4, V-A-B/t=Ct^4 and (V-A-B/t)/t^4=C. When adding quantities, the quantities must be equal in order for them to be added. C has to be a measureable quantity in order for volume to exist. When dimensions are written in terms of standard units (L,T,A,K,M), the result is [L3], [L3t], and [L3/t^4].
ment4ll
The volume of an object is given as a function of time by
V= A + B/t + Ct^4
Find the dimension of the constant C.
N/A
I don't understand dimensional analysis completely .. I understand it on simpler terms, but in terms of this problem I do not.
V - A = B/t + Ct^4
V - A - B/t = Ct^4
(V - A - B/t)/t^4 = C
is that correct?
Dimension analysis is just to find its units essentially.
When you are adding, the quantities must be the same. So if you have volume of on the left, A,B/t and Ct^4 all must have combined units of volume.
If that is the case, then what is the units of C?
also note that 2 quantities can only be added when their dimentions are equal.
what can you conclude from this?
I mean, yea I get that A, B/t and Ct^4 all are combined units of volume, they have to be. I don't understand how you get the units of C if it isn't the answer I posted.
Sorry if I'm noob at this, I've never taken a physics class in my life (besides this one).
So C has to be something measurable to volume right?
as A can be added to B, both have same dimensions... let's say [X]
now [X]/[T] = [C][T]4 = [V] = [M]3
can you find dim of C as well as A,B now?
Sorry guy, I'm just not grasping it at this point .. wouldn't the dimensions of A+B = X then? I'm confused about where the M3 comes from ..
dimensions is just like witing units in form of 7 basic standard units
what is the unit of 5m/s + 3m/s ??
M is the dimensional symbol for mass
7 dimentions:
Length: [L]
Mass: [M]
Time: [T]
Electric current: [A]
Temperature: [K]
Luminous intensity: [Cd]
Amount of substance: [Mol]
7 dimentions:
Length: [L]
Mass: [M]
Time: [T]
Temperature: [K]
Okay, the unit is m/s and the dimensions is L/T, now I understand that.
GOOD!
now that you are familiar with dimensions and that they don't change while addition or subtraction, can you now write the dimensions of A,B,C ??
Well I am assuming that C is Length while A is electric current and B is mass .. I'm trying to comprehend it man, but that is just guessing based on what you've explained :\
ment4ll said:
Well I am assuming that C is Length while A is electric current and B is mass\
Well how do you got these?
wait, would the deminsions of A, B, and C all be L3?
ment4ll said:
wait, would the dimensions of A, B, and C all be L3?
No, but the dimensions of A, B/t, and C·t4 are all [L]3, because each has to have the same dimension, which is the same dimension as V, which is also [L]3.
I told toy that treat dimentions just like units.
Ok what is unit of A in: (A-B)/t = 1kg ?
Thats what I didn't know
now I see that A=L^3, B=L^3t and C=L^3/t^4
I didn't know that you had to cancel out to get the dimension and I didn't know that V=L^3
V=L^3 because the formula for volume=lwh and those are 3 lengths multiplied together.. is that right?
Yes you are right but still A is not L3
Remember what you did ... You know Ct4 + <something> = volume
Now using table you find out that dimension of volume is [L3]
You also know that any quantity X can only be added to some quantity which has same units as X ...
(thats why 5m/s + 3m/s = 8 m/s ... but if someone says that find 5m/s + 3m/s2 ... you tell them to go home and study!)
... By all this can you conclude that Ct4 has same dimentions as that of volume i.e. [L3] ...?
So Dimension of C comes out to be [L3]/[T4]
Now can you find the correct dimensions of A ?
FAQ: Dimensional Analysis and constant
What is dimensional analysis?
Dimensional analysis is a mathematical tool used to convert units of measurement or evaluate the relationships between different physical quantities. It involves manipulating and canceling units to ensure that the final result has the desired units.
Why is dimensional analysis important in science?
Dimensional analysis is important in science because it helps to ensure the accuracy and consistency of measurements and calculations. It also allows for easy conversion between different units of measurement, which is crucial when working with data from different sources.
What are the benefits of using dimensional analysis?
One of the main benefits of using dimensional analysis is that it can help to identify and correct errors in calculations. It also allows for the simplification of complex equations and helps to ensure that the final result is in the correct units.
What is a constant in dimensional analysis?
In dimensional analysis, a constant is a numerical value that does not change when converting between different units. It is used to relate different physical quantities and allows for the simplification of equations.
How can I use dimensional analysis to solve problems?
To use dimensional analysis to solve problems, first, identify the known and unknown quantities and their respective units. Then, set up a conversion factor or ratio that relates the known and unknown units. Finally, use dimensional analysis to cancel out units and solve for the unknown quantity.
