vector
- 15
:[/B]An atomic explosion can be approximated as the release of a large amount of energy ##E## from a point source. The explosion results in an expanding spherical fireball bounded by powerful shock wave. Let ##R## be the radius of the shock wave and assume that ##R=f(E,T,\rho_0, p_0)## where ##t## is the elapsed time after the explosion takes place, ##\rho_0## is the ambient air density and ##p_0## is the ambient air pressure. Using dimensional analysis show that ##R=\frac{Et^2}{\rho_0}g(\pi_1)## where ##\pi_1## is a dimensionless variable. Choose it so that it involves ##E## to a negative exponent. What is ##\pi_1##?
The problem is that the relationship does not appear to be homogeneous. If ##\pi_1## is dimensionless, then the units of ##\frac{Et^2}{\rho_0}## must be the same as the units of ##R##. However,
##[E] = ML^2 T^{-2}##
##[t] = T##
##[\rho_0] = ML^{-3}##
##[p_0] = ML^{-1}T^{-2}##
##[R]=L##, where M is express in kilograms, T is in seconds, L is in meters.
What is it that I'm not getting right here?
On the other hand, I expressed ##\pi_1## as follows: ##\pi_1 = \frac{p_0 R^3}{E}##. Is this correct?
Thank you!
