Dimensional analysis in the formula for gyration frequency
In summary: Yes, you can do this in the SI too, i.e., you use the dimensions ##\mathrm{kg}## to measure mass, ##\mathrm{m}## to measure distance, and ##\mathrm{s}## to measure time.
jonggg
I have a question about dimensional analysis in the formula of the gyration frequency of synchrotron radiation of a relativistic particle (electron of charge e and mass m) in a magnetic field B. Leaving aside the adimensional Lorentz factor γ and numerical factors, the formula reads v ~ (e * B) / (m * c) (see for example eq. 9 in https://www.astro.utu.fi/~cflynn/astroII/l4.html). The dimensions of frequency are already given in the expression (e * B) / m, so how does the speed of light c in the denominator fit in here? I am afraid this must be something obvious about units system or convention, but I am confused. Help would be appreciated.
Yes, it has to do with the system of units being used. See the comments starting at the bottom of the second page here.
Likes jonggg and Ibix
Indeed, the formula refers to Gaussian (or Heaviside-Lorentz) units for the electromagnetic quantities, which is much nicer when formulating electrodynamics in a relativistically covariant way (as it should be done, because it's after all the paradigmatic example of a relativistic field theory).
In these units the Lorentz force reads (in the non-covariant formulation with ##m## the invariant mass of the particle)
$$m \mathrm{d}_t (\gamma v)=\vec{F}=q \vec{v} \times \vec{B}/c.$$
For the particle moving on a circle of radius ##r## this must be the centripetal force, i.e.,
$$m \gamma r \omega^2 = q v B/c=q \omega r B/c \; \Rightarrow \; \omega=q B/(m \gamma c).$$
Likes jonggg
It is a pain that the cgs-system is still in use. (Incidentally, you are deviating from your cherished Lectures on Theoretical Physics by Arnold Sommerfeld. ;-)
We could have gotten rid of it at least half a century ago, but some people (for example Edward Purcell in the Berkeley Physics Course) thought otherwise, that the cgs-system is "inherently" better. Generations of students have stumbled over this, and apparently this will continue forever, because there will always be some who think one system is superior to the other. Thus you cannot copy an equation from a book without checking whether the magnetic field is ## B_\text{cgs} = c B_\text{SI} ## or ## B_\text{SI} = B_\text{cgs} / c ##.
Of course, in relativistic work you can always set ## c = 1 ##. And I have no problem with that. But in the end you must be able to put back the factors you set to ## 1 ##. Dimensional analysis helps, but only if you remember what the dimensions should be. I have met people using cgs units who found checking dimensions too tiresome. They had a formula for a plasma effect that was off by ten orders of magnitude. It's now obvious that a factor of ## c ## was missing, but they didn't bother to check the dimensions.
Likes jonggg
He committed two sins. The lesser is the use of the SI in electrodynamics and the really severe one is the use of the ##\mathrm{i} c t## convention in special relativity.
A system of units, where components of a field have different dimensions is flawed from a physical point of view. From a practical point of view the SI is of course better to use.
You can do this in the SI too, i.e., you set ##\mu_0=\epsilon_0=1##, and you use the Heaviside-Lorentz system in its natural form. In the SI you have ##c##'s at very intuitive places. Dimensional analysis is simpler in the SI, because of the additional base unit A, i.e., you avoid the fractional powers of c, g, and s in the units of the electromagnetic quantities.
Likes jonggg
That's a silly argument. From this point of view all of physics is flawed that uses different units for time and space. Too bad that you are helping to perpetuate a "schism" that confounds students (and sometimes professionals too).
Well, that's why we set ##c=1## in theoretical studies involving relativity. It's "more natural". That's all I'm saying. Formulating electromagnetism in terms of SI units spoils the natural beauty of the theory when written in its most natural form, i.e., as a relativistic (Q)FT.
  • Haha
Likes WernerQH
FAQ: Dimensional analysis in the formula for gyration frequency
What is dimensional analysis in the context of gyration frequency?
Dimensional analysis in the context of gyration frequency involves checking the consistency of the units in the formula that defines the frequency at which a charged particle spirals around a magnetic field line. It ensures that the derived formula is dimensionally consistent, meaning that both sides of the equation have the same units.
Why is dimensional analysis important for the formula of gyration frequency?
Dimensional analysis is crucial because it helps verify that the formula is physically meaningful and correct. It ensures that the units on both sides of the equation match, preventing errors in calculations and improving the reliability of the results.
What are the common units used in the formula for gyration frequency?
The common units used in the formula for gyration frequency include Tesla (T) for magnetic field strength, Coulombs (C) for electric charge, kilograms (kg) for mass, and seconds (s) for time. The resulting unit for gyration frequency is typically Hertz (Hz), which is equivalent to s-1.
How can you apply dimensional analysis to derive the formula for gyration frequency?
To apply dimensional analysis, you start with the physical quantities involved, such as charge (q), magnetic field strength (B), and mass (m). By analyzing the dimensions of these quantities and their relationships, you can derive the formula for gyration frequency, which is typically given by \( f = \frac{qB}{2\pi m} \). Ensuring the units on both sides match confirms the formula's correctness.
Can dimensional analysis identify errors in the formula for gyration frequency?
Yes, dimensional analysis can identify errors in the formula for gyration frequency. By checking the consistency of the units, any discrepancies can reveal mistakes in the derivation or application of the formula, allowing for corrections to be made before further use.
