Dimensionality of the wavefunction in relative state
In summary: In the original conversation, it is mentioned that the concept of spooky action at a distance is eliminated in the RSF and MWI interpretations, which use 3-D wavefunctions. The discussion then goes on to discuss the use of different bases for wavefunctions. The reason for using the position basis is not explicitly stated, but it can be inferred that it is because it allows for correlations between separated objects. The question about entanglement in the momentum basis and Einstein's thoughts on this is a separate topic that is brought up later in the conversation.In summary, the conversation discusses the use of different bases for wavefunctions, specifically the position and momentum bases, and how they relate to the concept of ent
  • #36
atyy said:
Sure, but that's not what the decoherence form of MWI does. The decoherence is intended to pick a preferred basis.
Of course. And it does. But why would the ability to further expand entangled states into 3D particle states invalidate decoherence theory? Of course with fine-branching it's all too easy to lose track of macroscopic meaning. This is very akin to statistical mechanics - merely defining a low entropy state as one with a small number of microstates is not sufficient, you need to identify the ones that exhibit low entropy at the classical thermodynamic level. And it's not easy. So it is with fine branching in QM: you need to identify or at least create a "measure" of the branches which are particular pointer states. Much easier to start with a more appropriate basis - the pointer states themselves - and work down, showing that a formulation is possible in 3 dimensions. That's non-locality and entanglement and multi-dimensional phase space all subsumed in superposition. Then we can work in the other direction, just retrieving the fact that multi-particle states have a very big basis. This allows us to develop decoherence theory separately from the fine-branch model. Which is what this topic is about :)
  • #37
But the coarse-grained branches will be superpositions of the fine grained branches. Only the fine grained branches are products of 3D wave functions, so the coarse-grained branches will not be, since they are superpositions of products.
  • #38
Exactly. The coarse-grained world of Schrodinger's Cat is a vast collection of fine-grained worlds - worlds where particles have independent 3D wavefunctions. Different bases, different branching, same state. How is that a problem?
  • #39
That's fine. Then I just don't understand your motivation. Usually people worry about the 3D wave functions when they think something about notions like "physicality" or whatever. In the decoherence version, since the 3D wave functions don't apply (because the coarse-grained branch is a superposition of them), then it would seem that the fine grained "physicality" has been lost.
In case you are wondering, I understand this better in the context of Copenhagen. One can always have the 3D wave functions, since that is essentially how the Hilbert space of the whole system is defined. However, this is not considered physical in the context of Copenhagen, because it is the Born rule that makes things physical, and then we have to square the wave functions and have interference between branches, so the 3D wave functions remain formal, not physical.
  • #40
My motivation is to use a foundation in which 3D wavefunctions are fundamental, as this removes entanglement from the picture whilst retaining reality - albeit as a superposition.
I understand your Copenhagen view. However I do not agree that the Born rule makes things physical. The Born rule just tells us the formula for the density matrix. What makes things physical is some sort of postulate such as "Nothing is real, Man, until we look at it". That is pure metaphysics, superfluous metaphysics at that. And accordingly detestable :)
I do not think interference affects the picture. The 3D functions remain fundamental. Interference requires us to "add and square", not "square and add", which means we have quietly changed basis. Why would we expect the new picture to make sense in terms of particle states when we have just exchanged them for something different? Schrodinger's cat is still a cat whether it's regarded as a collection of atoms or holistically as, well, a cat.
  • #41
Well that seems to have finished the topic off neatly enough. Thanks atyy.
9K
