Dimensionless form of the time-independent Schrodinger equation
The discussion focuses on transforming the time-independent Schrödinger equation into a dimensionless form for a free particle. Participants explore how to eliminate constants like mass and energy through variable substitution, specifically using z = (ħ/sqrt{2m})x. The chain rule is emphasized as essential for changing the differentiation variable while maintaining the wavefunction's integrity. Clarifications are made regarding the application of the chain rule in derivatives, demonstrating that d/dx can be expressed in terms of d/dz. The conversation ultimately highlights the importance of understanding variable substitution in quantum mechanics.
ehrenfest
For a free particle, show that the time-independent Schrodinger equation can be written in dimensionless form as
d^2\psi(z)/dz^2 = -\psi(z).
I do not see how you would get rid of the m (with units mass) in front of the del in the SE (or the other constants for that matter)...
Substitute z=[hbar/sqrt{2m}]x
Sorry, this is probably a really basic question but if I have psi(x(z)), how do I get psi(z)?
psi(z(x))=psi(z). They are the same thing. Meir is suggesting you change the variable you differentiate wrt, not the psi. Use the chain rule.
Just so we are on the same page, the equation I am starting with is:
-\frac{\hbar^2}{2m}\frac{d^2}{dx^2}\psi_E(x) = E \psi_E(x)
where (I thought) E was a constant not an operator.
So, first, I do not see how that substitution would get rid of the constant E.
Second, if I change variables I get
-\frac{\hbar^2}{2m}\frac{d^2}{dx^2}\psi_E(v(x)) = E \psi_E(v(x))
I cannot change the dx in the second derivative because that is part of an operator not a variable, right?
Then if I use the chain rule one time, I get:
d/dx psi(z(x)) = d/dx psi(z) * d/dx z(x) from which I do not see how you get a d/dz operator into the equation
Sorry, it should have been sqrt{mE}.
If z=ax, d/dx=ad/dz.
Look at your calculus text.
Sorry, I cannot find that rule in my calculus text. Does it have a name? I know how to substitute variables with integrals, but I have not seen it with derivatives. If you were going to do it with an integral it would be
dz = a*x*dx but how do you get the derivative operator form? Sorry again, I should probably know this!
z = a x
Now, \frac{d}{dx} = \frac{dz}{dx} \frac{d}{dz} = a \frac{d}{dz}
It's just the chain rule applied to a very simple case.
nrqed said:
z = a x
The chain rule states that if a = f(b) and if b = f(c), then da/dc = da/db * db/dc.
Your comment obviously makes sense with the Liebnex notation when you treat differentials like fractions, but I do not see how you get that directly from the chain rule. Apply, d/dx to both sides of the equation doesn't work...
nrqed said:
z = a x
I think I see now. You can just replace d/dx with any dy/dx for any function y and you get the chain rule. Just a little too abstract for me!
To show how it comes from the chain rule, consider a function y(z) and z is a function of x itself z(x).
Then the chain rule says
dy/dx = dy/dz dz/dx
Now let's say that z= ax. Then we have dz/dx = a (where a is a constant)
So
dy/dx = a dy/dz
In this thread, you must think of the wavefunction psi as playing the role of y.
Psi is initially a function of x. But then you imagine replacing all the x interms fo z in order to get a function psi(z). Plugging back in the Schrodinger equation, you then have to deal with calculating
\frac{d \psi(z)}{dx}. Using the rule above, you see that this is equal to a \frac{d \psi(z)}{dz}.
  • · Replies 16 ·
