Exploring 4th Dimension Beyond 1,2,3: Is It Possible?
  • Thread starter Spastik_Relativity
  • Tags
    Dimensions
In summary, Dimension is a topological concept that is necessary to define a space and to distinguish between a line and a plane. Dimension is also related to the notion of distance and to the concept of neighborhood.
Spastik_Relativity
47
Ive been reading a couple of threads concerning the 4th(non-time) dimension. This has got me thinking wether we are closer to realising the 4th dimension than we actually think.
Say for instance a point A in the 1st dimension can move left to right in its dimension. In the 2nd dimension an identical point can move left to right, and up and down. In the 3rd an identical point can move left to right, up and down, and back and forth. But what if that particle or point wasn't to move at all. Is it possible to define what dimension it lies in?
Just a thought that confused me for a while. :rolleyes:
lol its funny, and logically yes it is possible. If that point never moves it still exist in a spot within the system or universe or whateva. Therefore, from your reference point, whateva it may be, you can locate it whereva it exist relative to you. But this doesn't fit in with reality because everything is always in motion, but no one has ever proved that it's impossible to reach absolute zero. Also even if things are always in motion you can still locate any point relative to your own so actually i guess it does represent reality acurately
A single point has no dimension. It's trajectory (in coordinate space, phase space, etc.(?)) has dimension. The notion of dimension is immanent to the notion of manifold. I think you can't define a non-trivial manifold with only one point.
P.S.
Many dimension threads, lately. :confused:
Dimension is in essence a topological concept. This means that the concept of "open balls", the set of points "close to" a given point, determine the dimensionality of a space. It's not necessary for any points to actually move, but it is necessary to have some concept of what points are close to other points in order for the space to have a topology and hence a dimension.
The usual way to define a topology is to have a metric, a way of measuring the distance between any two points. Then one can say that points within some given (small) distance delta are "close to" or "in the neighborhood" of some point. These sets of points that are close to other points are called "open balls" or "open sets" in topology.
Given a topology, a space naturally has a "Lebesque covering dimension". (This is something I learned about from this forum, btw). This notion of dimension - the "Lebesque covering dimension" requires (IMO) the least amount of structure to define - the more usual notions of dimension, the notion of the dimension of a vector space for instance, require more axioms to define what a vector space is. (A manifold requires even more structure to define than a vector space - every manifold has a tangent vector space at any given point, and all the tangent vector spaces have the same dimension, so the dimension of a vector space defines the dimension of a manifold).
Toppology is important to the concept of dimension for the following reason. It is possible to map all the points in a line to all the points in a plane with a 1:1 mapping!
Such mappings, however, are not _continuous_ - they do not preserve the structure of the neighborhood (what points are close to other points).
Mappings which preserve the neighborhood structure are homeomorphisms. In order to tell a homeomorphism from a non-homeomorphism, one needs a concept of neighborhood. This makes the concept of neighborhood _necessary_ to define dimension - with no concept of neighborhood, we can't distinguish between a line and a plane. The existence of the Lebesque covering dimension makes the concept of neighborhood _sufficient_ to define dimension.
See
this past thread
for more - another poster here (Chronon) introduced me to the concept.
Related to Exploring 4th Dimension Beyond 1,2,3: Is It Possible?
1. What is the 4th dimension?
The 4th dimension refers to a theoretical dimension beyond the three dimensions we experience in our daily lives. It is often described as a spatial dimension that is perpendicular to the three dimensions of length, width, and height.
2. Is it possible to explore the 4th dimension?
While it is not currently possible to physically explore the 4th dimension, there are mathematical models and theories that allow for its exploration and understanding.
3. How is the 4th dimension different from the other dimensions?
The 4th dimension is different from the other dimensions in that it is not easily observable or perceivable. It is often described as a dimension of time or a dimension of possibility and potential.
4. Can we visualize the 4th dimension?
It is difficult for humans to visualize the 4th dimension as it is beyond our three-dimensional perception. However, there are mathematical models and computer simulations that can help us understand and visualize it.
5. What implications would exploring the 4th dimension have?
Exploring the 4th dimension could have significant implications for our understanding of the universe and our place in it. It could also potentially lead to advancements in mathematics, physics, and technology.
  • Other Physics Topics
  • Astronomy and Astrophysics
  • Science Fiction and Fantasy Media
  • Beyond the Standard Models
  • DIY Projects
