Dimensions of A and B are different, how to express?
  • B
  • Thread starter Indranil
  • Tags
    Dimensions
In summary, multiplication and division are the same, but addition is not. The difference is that multiplication creates a new dimension, while addition does not.
Indranil
177
If the dimension of A and B are different, then how to express the dimension of A and B together? how to write?
Simple rule: multiplications are o.k., additions are not. Can you give an example what you mean, and especially what "together" means?
Could you explain why multiplications are ok but additions are not? It could be division like A/B or could be A-B. I am confused. Please get it clear.
If you add a measured number of pounds (force) to a measured number of miles, you get garbage. If you change one unit or the other, the result will change. But by no fixed proportion.
If you multiply a measured number of pounds (force) by a measured number miles, you get a quantity with units of pound(force)-miles. This is a unit of energy (or of torque). If you change one unit or the other, the resulting product will change in proportion to the ratio of the new and old units.
Units can be understood as a constant of proportionality that allow you to relate measurements made using one scale to measurements made using another.
Likes cnh1995
##A/B = A \cdot B^{-1}## and ##A-B= A + (-B)##, so from a mathematical point of view, there is no difference between multiplication and division, resp. addition and subtraction. Addition is obviously not allowed, because there is no common domain where it would make sense to add, e.g. length to time. By multiplication we define a new domain of the multiplied dimension, e.g. distance per time results in velocity which is a new dimension. One could probably formally construct domains with length plus time, but this has no useful real life correspondence. It will always remain a pair (length ; time) whereas length / time consists of all possible velocities.
Thank you very much, sir.
Related to Dimensions of A and B are different, how to express?
1. How do you express the difference in dimensions between A and B?
The difference in dimensions between A and B can be expressed using various mathematical symbols, such as the minus sign (-) or the division symbol (/). For example, if A has dimensions of 10 units and B has dimensions of 5 units, the difference in dimensions can be expressed as A - B = 5 units or A / B = 2.
2. Can you provide an example of how to express different dimensions?
Yes, for instance, if A has dimensions of length, width, and height (LWH) of 5cm, 3cm, and 2cm respectively, and B has dimensions of LWH of 8cm, 6cm, and 4cm respectively, the difference in dimensions can be expressed as A - B = 3cm, 3cm, 2cm or A / B = 5/8, 3/6, 2/4.
3. Is there a specific unit that should be used to express dimensions?
The unit used to express dimensions will depend on the type of dimensions being compared. For example, if A and B have dimensions of length, the unit used could be centimeters, meters, or inches. If A and B have dimensions of volume, the unit used could be cubic centimeters or cubic meters.
4. How can you express the difference in dimensions visually?
One way to express the difference in dimensions visually is by using a diagram or graph. For instance, a bar graph can be used to show the difference in dimensions between A and B, with the length of the bars representing the dimensions for each object.
5. Are there any other ways to express the difference in dimensions?
Yes, the difference in dimensions can also be expressed using words or phrases. For example, the dimensions of A can be described as larger or smaller than the dimensions of B. This method may be more useful when explaining the difference in dimensions to someone who is not familiar with mathematical symbols.
  • Other Physics Topics
14K
20K
