Diodes at super low temperatures
  • Thread starter R33E8
  • Tags
    Diodes
In summary, a LED would still light up as a superconductor, but it's not a proper semiconductor and it would not be possible for a HTS material to be both a semiconductor and a superconductor.
R33E8
Yesterday, my Chemistry professor talked about super low temperatures and semiconductors becoming superconductors. So I was wondering, would a LED still light up as a superconductor?
There are -as far as I know- no "proper" semiconductors (in this case something with a direct bandgap since the question concerns a LED) that become superconducting at low temperatures (you can play around with proximity effect etc, but that is not the same thing).
That said, I don't think there is any known fundamental reason why it would be impossible for a HTS material to be a semiconductor at room temperature and superconducting at low temperatures.
However, it could obviously never be both at the same time since there couldn't -by defintion- be a bandgap in a superconducting material. So I am reasonably sure the answer to your question is no.
You can make Silicon/Boron superconduct at very low (0.1k?) temperatures but I don't think anyone has found a use for it.
And as f95toli said, it's no longer a semiconductor
Interesting, I did not know that Si:B is a superconductor.
However, according to the abstract in Nature (I'm at home now so I can't access the full paper)
http://www.nature.com/nature/journal/v444/n7118/abs/nature05340.html
this only happens when the concentration of B is several percent, meaning the silicon is already metallic.
I am a surprised that Tc is as high as it is, 0.35K is quite easy to reach meaning Si:B might even be useful if one could deposit films.
At low temperatures, forward biased junction diodes make very linear thermometers. This is consistent with the ideal diode equation.
V = (kT/e) Ln (I/I0)
I = forward current, k = Boltzmann's constsnt, T = temperature in kelvin, and e = electron charge.
Here is a recent paper:
GaAs Junction diodes as cryogenic thermometers
Cohen, B.G.; Goordman, R.V.; Snow, W.B.; Tretola, A.R.
Electron Devices Meeting, 1962 International
Volume 8, Issue , 1962 Page(s): 74 - 76
Digital Object Identifier
Summary: It has been observed that the forward voltage drop, at constant forward current, of a GaAs diffused p-n junction varies almost linearly with temperature from 2.0° K to above 300° K. Since carrier "freeze out", at low temperatures is not observed, these junctions make excellent cryogenic thermometers. In addition these diodes exhibit good repeatability on temperature cycling and an insensitivity to magnetic fields. The sensitivity of the devices measured near room temperature is Δ/VΔT∼ -3.5 mv/°C; If= 0.1 µA Δ/VΔT = - 2.0 mv/°C; If= 1.0 µA The sensitivity decreases slowly toward lower temperatures and at liquid Helium is: ΔVΔT∼ - 1.5 mv/°C and is essentially independent of current. This high sensitivity over such a wide temperature range is unique among cryogenic temperature indicators.
We used to use Si diodes in a tiny SOT23 surface mount package, they had a pair in series so you got twice the output, feed it a 100uA from the micropower circuit example in Horrowitz+Hill. They are tiny and cheap, although you can buy the same thing calibrated(?) from Oxford Instruments for a fortune.
I only ever used them at LN2 - there might be too much power dissipation if you ran them continually at very low temps.
Slightly OT again
I've used standard SMD GaAs diodes down to 4K, they work but are unpredictable (probably due to the packaging) and they need to be cycled a few times before they reach any kind of stability. Some schottky diodes also work reasonably well.
In fact, MOST components can be used as thermometers. For many years the "standard thermometer" in low temperature physics was a particular type of Allen-Bradley carbon resistor (sliced up into smaller pieces) which just happened to work well. You can still buy them from companies that were smart enough to buy a lot of them before Allen-Bradley stopped making them (but now they cost a fortune).
The main problem is that you still need to calibrate your DIY thermometer somehow.
The advantage of DT470 (which is a Si diode) and other similar modern commercial sensors is that they follow a standard curve (they are made in such a way that they are almost identical), meaning even an uncalibrated sensor is good enough for many applications (something like +-0.2K below 10K). And they are only something like £100-200 which is not bad considering how much time (and expensive) it can be to calibrate a sensor yourself (although a calibrated sensor is significantly more expensive).
At lower temperatures (below say 2K) resistive RuO2 is the most common type of sensor, although e.g. capacitive sensors are also used.
Low temperature thermometry is actually quite tricky, especially when you go down to mK temperatures where self-heating becomes a serious issue.
There was also a 2 wire current source (LM504?) that gives 0.1mA/Kelvin (so it gives 27.3mA at 0C) so it was trivial to hook up as a temperature regulator. Officially it only worked down to -40C but about half of a batch would work down to LN2.
Then the maker tightened up their manufacturing process and none of them worked cold.
Related to Diodes at super low temperatures
1. What is the effect of low temperatures on diodes?
At low temperatures, the performance of diodes can be significantly affected. The conductivity of the semiconductor material decreases, causing a decrease in the diode's forward voltage drop and an increase in its reverse current.
2. Can diodes be used at super low temperatures?
Yes, diodes can be used at super low temperatures, but their performance may be limited. Specialized diodes such as cryogenic diodes are designed specifically for use in extremely low temperatures.
3. How does the temperature impact the reverse breakdown voltage of a diode?
The reverse breakdown voltage of a diode decreases with decreasing temperature. This means that at super low temperatures, the diode may experience a higher reverse current and potentially fail if the reverse voltage is exceeded.
4. Do diodes have a minimum operating temperature?
Yes, diodes have a minimum operating temperature that is specified by the manufacturer. Operating a diode below its minimum temperature can result in decreased performance and potential failure.
5. What are the potential applications of diodes at super low temperatures?
Diodes at super low temperatures have a variety of potential applications, such as in cryogenic systems, scientific research, and space exploration. They can also be used in specialized electronic devices that require operation at extremely low temperatures.
  • Atomic and Condensed Matter
