Dipole Moment of a Hollow Sphere, simplify calculation
In summary, the dipole moment of a hollow sphere can be simplified by considering its uniform charge distribution and symmetry. The total dipole moment is derived from the product of charge and the distance from the center to the charge distribution's center of mass. For a hollow sphere, the dipole moment is effectively zero due to the equal distribution of charge around the center, leading to cancellation of contributions from opposite sides. This simplification highlights that a hollow sphere does not produce a net dipole moment, regardless of its size or charge.
LeoJakob
24
Consider the non-uniformly charged hollow sphere with radius ##R## and charge density##
\rho(\vec{r})=\rho_{0} \cos \theta \delta(r-R) .##
Calculate the dipole moment ##\vec{p}##
\vec{p}=\int \vec{r} \rho(\vec{r})\mathrm{d}^{3} r .
is there an easier way to calculate the dipole moment? I described ## \vec r## in spherical coordinates. I thought at first that due to the symmetry I can assume that dipole-moment only points in the ##z##-direction, but the charge distribution is inhomogeneous, so I made the following calculation:
My calculation results in $$\vec{p}=\int \vec{r} \rho(\vec{r}) \mathrm{d}^{3} r=\int \limits_{0}^{2 \pi} \int \limits_{0}^{\pi} \int \limits_{0}^{\infty} R\left(\sin \theta \cos \phi \vec{e}_{x}+\sin \theta \sin \phi \vec{e}_{y}+\cos \theta \vec{e}_{z}\right)r^{2} \cdot \delta(r-R) \rho_{0} \sin \theta \cos \theta d r d \theta d \phi =\frac{4}{3} \rho_{0} R^{3} \overrightarrow{e_{z}}$$
Which is the correct result but the calculation of the integrals took quite some time. In the end I realized that the dipole moment,indeed, only has a ##z##-component, could I have recognized this earlier and thus simplified my calculation? I'm unsure because the charge density is not homogenous.
Weird, I would think that it was only necessary to do a double integral instead of a triple integral to calculate the dipole moment of this specific distribution. My interpretation is that there is only charge on the surface. Ah I see you used the delta function never mind.
I presume ##\theta## refers to the polar angle. ##\cos \theta## is even about the ## z-axis##. If you go ##\theta## clockwise from the z-axis and ##\theta## counterclockwise from the z-axis , draw the vectors, you will see the components in the xy-plane cancel out.
Likes LeoJakob
FAQ: Dipole Moment of a Hollow Sphere, simplify calculation
What is the dipole moment of a hollow sphere?
The dipole moment of a hollow sphere is generally zero because the charge distribution is symmetric. For a uniformly charged hollow sphere, the charges are evenly distributed over the surface, resulting in no net dipole moment.
How can we simplify the calculation of the dipole moment for a hollow sphere?
To simplify the calculation, you can use symmetry arguments. For a uniformly charged hollow sphere, symmetry dictates that the contributions to the dipole moment from all parts of the sphere cancel out, leading to a net dipole moment of zero. Therefore, detailed calculations are often unnecessary.
Does the presence of an external electric field affect the dipole moment of a hollow sphere?
In the presence of an external electric field, the charges on the hollow sphere may redistribute, potentially inducing a dipole moment. However, for a perfect conductor, the internal charges will rearrange to counteract the external field, maintaining a zero internal field and thus no net dipole moment inside the sphere itself.
What if the charge distribution on the hollow sphere is not uniform?
If the charge distribution is non-uniform, you would need to calculate the dipole moment by integrating the charge density over the surface of the sphere. The dipole moment \(\vec{p}\) is given by \(\vec{p} = \int \vec{r} \sigma(\vec{r}) dA\), where \(\sigma(\vec{r})\) is the surface charge density and \(\vec{r}\) is the position vector.
Can the dipole moment of a hollow sphere be non-zero in any scenario?
Yes, the dipole moment can be non-zero if the charge distribution is asymmetrical. For example, if the sphere has regions with different charge densities, the symmetry is broken, and a net dipole moment can arise. In such cases, you would calculate the dipole moment by integrating the contributions from each charged element on the sphere's surface.
